Scratch Removal
Old Dec 12, 2004 | 09:26 AM
Benjamin Russick's Avatar
Question Scratch Removal
OK, I did a search, but got a lot of confusing info... Is there any products that will remove light scratches and surface swirls? I think my buddy's dog may have scratched up my car while she was in the garage. I also have some swirls from way back. These aren't real deep, but since there are quite a few, it looks ugly. The car is painted black if that helps. Thanks! Ben
Old Dec 12, 2004 | 10:12 AM
Brian2001SS's Avatar
Try doing a search on Menzerna and the Porter Cable buffers. That will get you going. I am sure the swirls can be done with an orbital buffer, but the scratches depend on how deep they are. Those may come out with a regular buffer, but usually takes someone that knows what they are doing so you don't make a bad situation worse.
Old Dec 12, 2004 | 10:53 AM
DARK AGE 53's Avatar
3M Finesse-it II Finishing Material and a Porter Cable 7424 buffer/polisher with a foam pad is what you want.
Al
Old Dec 12, 2004 | 11:15 AM
ZaneO's Avatar
Lots of polishes out there that will remove light scratches and swirls. Menzerna, Poorboy's, Einszett, 3M, etc.
Old Dec 12, 2004 | 11:29 AM
SShotgun_Rider12's Avatar
I have had good success removing swirls with Eagle 1 Nanowax.
Old Dec 12, 2004 | 02:12 PM
ZaneO's Avatar
That's odd I wasn't aware that Nanowax had abrasives in it.
Old Dec 12, 2004 | 02:34 PM
Orange Crush 408's Avatar
Dark age 53 is exactly correct. I co-own a body shop and this what we use.
Old Dec 12, 2004 | 05:14 PM
I'm guessing a good buffer would be at least $100? Damn...I was hoping there would be a cheaper fix.
Old Dec 12, 2004 | 06:34 PM
It's a little more but you'll probably have it for life, http://www.coastaltool.com/cgi-bin/S...3aa+1092442819 .
Old Dec 13, 2004 | 05:13 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
The Porter Cable Polisher is the best tool you'll buy for your car - it's worth the cost the 1st time you use it - and you'll use it over & over...
I use Menzerna Intensive Polish, then Final Polish, then Formula 113 Wax with the Porter Cable on my Black T/A - not a swirl/scratch to be found
-Jay-
Old Dec 13, 2004 | 07:25 AM
sQuashed's Avatar
Al
Come out of the Dark Age, Dark Age.... (pun intended)
3M has Perfect it III out now... Finesse it II is old news !!!
In all honesty, I use 3M P-III Machine Glaze with my PC with great results .
Old Dec 13, 2004 | 11:42 AM
I don't like to recommend something I've never used before so that's why I recommened the Finesse-it II instead, I'm not sure what there using today but the last time I knew the G.M plant I retired from was still using the Finesse-it II.
Old Dec 14, 2004 | 08:58 PM
I don't know what Nanowax has in it; I just know that it works on swirls.
Old Dec 14, 2004 | 10:13 PM
6']['9's Avatar
theyre called fillers. and btw Perfect it III has been out for some time now. I noticed when i went to orileys they have a perfect it 3000 unless thats the same thing i dunno
Old Dec 14, 2004 | 10:19 PM
msbz_ls1's Avatar
Wow..its gotten alot cheaper $119.00 is alot cheaper then I figured it would be.
