Someone please make a different hood for T/A's!
#81
Originally Posted by JasonWW
If anyone can find a car pic they like and a scoop pic that is roughly from the same angle I'll put the 2 together for you.
School? I taught myself! Download yourself a copy of Adobe PS 6 or 7 from a shareware program. (Not that I condone that) It includes a tutorial usually and you can find books on it at the used book stores. There are newer versions of PS, but I would stick to 6 or 7. You will get better over time. I don't think I know even 1/4 of what can be done. Still it's fun to mess with.
See what I mean?
See what I mean?
http://www.freewebs.com/raleighta/
#82
Here's a quick PS job. Those reflections are hell.
Also, don't forget that the overall hood is bulged up higher around the windshield.
#83
i was going to try to make my own camaro ss hood for my ta saw a photochop and it was awsome just a flat hood no air indents with the ss scoop
#84
Originally Posted by Raleigh TA
In person, I think the scoop needs not be larger to fit on the 4th gen. Think about it...the 2nd gen is a larger car, if the scoop was right on the larger car, why make it even larger on a smaller car? I like the Heritage, but the scoop is a bit too large for me to consider for my daily driver.
So, since you are proficient with PS, could you graft the fender heat extractor from the Heritage onto this 4th gen, but leave the stock fender vents? I'll post the base pics on my site.
#85
Could you take the car from this post and reverse the red and white? That is my plan B if I can't swing the bucks to repaint my red TA to white when I install the shaker. It sure would be nice to see it.
I couldn't even find a decent red car, so if you have some red car pics from that angle, I can try again. I almost gave up on this one, it was so hard. The white shaker blends in a little too much, but I'm not sure how to correct that. Anyway, here it is:
#86
If you want a much better idea of what the white shaker on a red car would look like you can paint your current hood with the white stripe and white shaker. Then find some nice red car photos like yours with a stock hood. Photograph your hood at the same angle as the car and with similar lighting. I can then combine the 2 for a very realistic image.
Are you saying you saw a photoshop of the SS scoop on a stock TA hood? Still have the pic? I'd like to see that.
#87
Possible Scammer - Buyer Beware - Issues Unresolved
Originally Posted by tbird31
OMG THAT IS SEX ON WHEELS! That is so incredibly awesome looking...when I get my LS1 formula WS.6 i'm SO doing that! haha...i can't wait till i get my car...lol...someday...damn V6
#88
Originally Posted by 00ls1
i stole this idea from jasonww and i am actually planning on doing this, and being the fisrt person with and ls1 trans am with a cowl hood.
Something like this Caprice bulge might go well on the TA hood.
#92
I'm not sure what you mean. A regular cowl hood like this blue one?
#93
I couldn't really make that white car red. It's pretty easy to change colors, but white is a lack of pigment, so you it's hard to change. I'm not good enough to paint it red in PS and make it look realistic either, so I just found a decent looking red car and grafted the shaker and stripe on it and changed the red to white. It's not perfect, but gives you a rough idea of how it would look.
Sorry to give you a frustrating job, and thanks for your perserverence.
RC
#94
I thought that extra heat extractor just didn't blend in at all, style wise. I'd either run it or the stock vents, but not both.
Raleigh TA, all I know is that you have a LS1 4th gen. What color is your car now? TA or Formula? Any pics?
Also, did you make your shaker yourself or buy it?
#95
kind of a mix between both. it would follow the crease in the hood that comes from around the headlight that goes to the back corner of the hood. and will be about a 2-3" higher in the back
I think the front half of the stock hood looks pretty good, it's just that flat spot on the top rear section that really needs something. A shaker, bulge, heat extractor, something.
Another thing, if you measure our hoods real closely you'll see they are only 1/2" less in height compared to the Ram Air hoods. The Ram Air hoods look a lot taller because the sides of the hood doesn't bulge up like the stock hoods. You'll notice the Ram Air sides are flat. I think we could create a cowl induction look if we just pushed down the sides of the hood where it starts to bulge upward near the creases. Can anyone follow that? It's hard to explain.
#97
Originally Posted by HPP
What about a C5-R or Evo style heat/air extractor on the hood? (Evo style might work better)
If you have pics, lets' see them. I might be thinking of the wrong thing.
Speaking of heat extractors, I did a few PS of a car with them on the sides of the hood along with some different stripe packages. Check these out.
#99
Anyone here worked with foam?
I'm thinking about carving some foam to make a hood bulge of some kind. Shape it, add a layer of bondo, sand it, and add a quick coat of paint. Then set it on my hood, wet down the car and snap some shots. Then Photoshop out the edges to make it look like it's molded in.
I'm trying to think of a quick way I can make these so I can knock out several different shapes and styles without costing a lot of money or taking a lot of time.
Once I find something I like, I'll do it up in fiberglass and take my time to make it right.
I figure I'll need to buy a little sander like this.
Anyone have any suggestions or hints?
#100
Originally Posted by Trans_Am05
personally id like to see a ws6 hood crossed with the 4 ports extractor hood i forgot what it was called, that would be a awsome new hood. id get it if they made one but who knows maybe someone has it custom made already if n e one does please post up some pics
