Stratches and Swirls with a PC
Once you've polished the swirls out, use NXT (or any wax or sealant) to protect your hard work and you're ready to cruise.
-Mike
Wash
Dry with waffle weave microfiber towel
Clay
Wash again (to get clay residue off)
Dry with waffle weave microfiber towel (I usually wash the towel and dry it while claying, mostly because I only have one waffle weave towel)
Menzerna Intensive Polish with an orange pad
Wipe off residue with 50/50 rubbing alcohol and water mix, using a clean microfiber towel
Menzerna Final Polish II with a white pad
Wipe off residue with just water and a different clean microfiber towel
Blackfire sealant applied by hand
Buff with yet another microfiber towel
It's a lot of work, but I only do all that twice a year. Once you've done it right, upkeep becomes very easy. I haven't tried Blackfire's gloss enhancing spray, but I have some on order and am anxious to use this, as it can be used like a quick detailer. The advantage of this is, you wash and dry the car, then use the spray to get rid of any lingering water spots, and it keeps the sealant in check.
I've also tried layering waxes on top of sealant with mixed results. Theoretically, this gives you protection for your sealant, since waxes evaporate. In my case, it didn't give me the same shine I wanted, so I went back to using Zaino as a sealant, which works well. My only gripe about Zaino is that I have to order it separately from the rest of the stuff I use.
-Mike
Lowes might carry it, pads you can get from a paint and body shop. Menzerna, you probably wont find any locally sorry.
Bought mine at Lowes, but it is the Porter Cable 7336 orbital sander. It's the exact same tool, just labeled different. It comes with a white pad, but it's not a very good one, as it's pretty small and a little too thick for my taste. As for other pads, Tommy Tool on Airport off I-45 has Milwaukee pads, which aren't bad, though the yellow pad is a little rough. I'm not sure if they sell the backing plate or not.
As for Menzerna, I'm not sure if anyone locally carries it. Most auto paint places carry the 3M products, which I haven't used, but a friend of mine used them on his Grand National and it looks great.
What part of town are you in? I just got a new shipment of Menzerna and such, so I have a little left from my last batch, if you'd like to try it out. Shoot me a PM.
-Mike
