Need advice on TA fixed headlight conversion
Neat little bugger, huh? I'm not sure how you would attach this style. Maybe just glue it over a small hole. There are several styles out there. The white round ones are easy to install, they just need a hole and you push them into it. There's a tiny air hole under it's cap.
Hmmm, found an interesting article that says you may need 2 vents. One on bottom and one on top.
http://www.freepatentsonline.com/20020181247.html
On my own setup I decided to do some serious cutting into the radiator crossbeam so I can set the projectors futher back. I don't have time to mess with my lights right now as I'm busy doing other stuff.
It has 4 vents.
With a zigzag shape to keep out water
and a small piece of foam to keep out dust.
The very lastest model of GM cars have switched to a simple piece of tape. It's about 1" in diameter and breathable, yet water resistant. All they do is mold a hole during it's construction and stick it over it. I wish you could buy those stickers, but I have no clue where to get them.
I'm going to be doing some pretty radical stuff to the front end as well. Front breather conversion, radiator relocation and I'm getting rid of that damned crossmember that's reducing the projector mounting depth.
BTW what are you going to do with your headlight frames...just the frames. I need a set to have chromed and would be interested in them if your selling them.
I'm doing an engine swap right now and will put the radiator back in the stock spot just to get it drivable. I'll probably stick some LT1 Camaro lights in there for the moment. Once I get it home I'll pull front bumper cover and get down to work.
I'm not ready just yet to give any parts away. It will be a few a weeks at least. Thankfully I have a 2nd car now so I can do some real work to the TA.
So do you want to sell your headlight frames? Or trade for mine...I will just have to ship mine too after I get the chrome ones back.
Have you tried getting some from a junkyard?
Or try this place:
http://www.tacreationsusa.com/
It may be a while before I'm sure I can give them up.
My idea is to make them with a better setup, HIDs, and dark black out lights that will still allow plenty light through them. I think that would look awesome since my Trans Am is black. it would look almost the same unless you look up close.
if anyone knows if this is possible, please PM me
