Need advice on TA fixed headlight conversion
My idea is to make them with a better setup, HIDs, and dark black out lights that will still allow plenty light through them. I think that would look awesome since my Trans Am is black. it would look almost the same unless you look up close.
if anyone knows if this is possible, please PM me
I've already talked about everything you just mentioned.
I'm going to be doing some pretty radical stuff to the front end as well. Front breather conversion, radiator relocation and I'm getting rid of that damned crossmember that's reducing the projector mounting depth.
So it begins.
Here's a closer look at the hinged shield and latching solenoid mechanism. Also note the 100% duty cycle solenoid. These are very similar to the ones I bought for my conversion project. I got this pair of Bi-xenon units for $100 shipped on Ebay, so screw converting the old ones.
Low Beam
High Beam
It has 3 wires to it, but I'm not sure why. I'll have to find a schematic on it somewhere.
The holes in the back that the bulb slides through are sized differently. I think it's just a cosmetic difference. I'm almost certain they take the same D2S HID bulb. The twist on bulb retainers work on both lights as well.
I used to read their forums all the time, but then they switched so only members can read them so I lost interest. I guess I need to sign up so I can catch myself up on the latest parts and mods.
I remember the good Hella ballasts costing $200 pr, now they are $279. Did they go up or are the gen3 units really new? Maybe it was a gen2 unit I'm thinking of.
So what I'm going to do to this one is flip the radiator the other direction and finish the fixed headlights.
(Ignore the other light cover, it is just resting there and not bolted up)
I may move it slightly to the left or right, but I think the middle looks about right. I want to keep it high as well so the light will hit the road in front of the car. Any thoughts?
I found a cool cat who is making these little solid state relay boards for these lights.
Wire hook ups are very easy. Most other units will hold the strong solenoid open for several seconds making it impossible to flash your highs on and off quickly. I need that functionality.
They are only about 20 bucks for a pair. He even has the 3 wire plug for the light if you don't already have them.
This link might last a while. If not, PM me for his website:
integramod dot tripod dot com/products/bixenon/bixenon.html
Some background from his site.
These projectors use solenoids to change the position of a metal shield, so that in one position it acts as a cutoff to prevent light from blinding oncoming drivers, and in the other position this restriction is removed for full brightness. The problem is that there are actually two solenoids in this package, a strong one for pulling and a weak one for holding, and consequently there is a 3-wire connector on the projector. For proper operation, the pull coil is supposed to be activated for about 1/5 of a second, and then turned off while the hold coil is still powered as long as high beams are desired. The hold coil alone is not strong enough to move the shield, only to hold it in the high-beam position. While it is possible to just use the pull coil all the time, powering the pull coil for long periods of time is not a good idea because it consumes a lot of power, and consequently generates a lot of heat. The solenoid is not designed to get that hot, so this would certainly reduce its lifespan a great deal, and it would probably burn out quickly.
Normally, in the E46 car, the solenoids are triggered by a special circuit that is located in the ballasts which came with that car. If you're using these E46 bixenon ballasts, then you don't need my circuits at all (go here to see how to use this functionality), but most people buy these components separately on Ebay and end up using different ballasts which don't have this extra circuit built-in. So I designed these circuits to handle this.
I have seen another circuit on the internet for controlling these solenoids, however this circuit uses a relay and a capacitor and resistor to achieve the proper delay. While this probably works (I haven't tried it), I believe my circuit to be better because it uses a MOSFET and therefore has no moving parts unlike a relay-based circuit, making mine extremely reliable. It is also much smaller, and could be easily hidden inside a headlight housing or other enclosure.
Either way, I'm anxious to see how it turns out.
What makes you think I need to fill that empty space?
My general design hasn't changed in the last 2 years. Go back to post #94 and check it out.
--_ [bumper] _--
-- being the low beams and _ being the high beams. Keep the projector up high like you have it mocked up there and a high beam slightly lower and closer to the edge of the bumper. Would be pretty evil looking IMO.
From post #152.
