Clear Corners
Old Mar 7, 2005 | 03:14 AM
BuBbABFP's Avatar
Default Clear Corners
Hey guys, i just got some clear corners, i have not installed them yet, i have no time. Is it hard to do so?
Old Mar 7, 2005 | 03:54 AM
SRfastZ's Avatar
nope just remove the HEADLIGHT
Old Mar 7, 2005 | 06:03 AM
Arachnotron's Avatar
I'd recommend filling the seam where the housing and the lens come together with some clear RTV sealant to prevent leaks.
Here is a write-up of the install
https://ls1tech.com/forums/showthrea...dlight+removal
I skipped steps 1 and 5.
Old Mar 7, 2005 | 11:59 AM
amit's Avatar
are you sure you have to take the headlights out?
i think you can get at them from under the vehicle.
Old Mar 7, 2005 | 12:07 PM
GregWS6&z28's Avatar
MUCH MUCH easier by taking the headlight out. You can get the headlight out in like 1 minute
Old Mar 7, 2005 | 12:12 PM
1972chevelle454's Avatar
yea it was simple, i took out the headlight
Old Mar 7, 2005 | 12:43 PM
amit's Avatar
my halos were an absolute pita to put in.. im never taken those thiings out ever! hahaha.
im gonna go through the bottom. i'll get the car on a hoist
Old Mar 7, 2005 | 02:17 PM
MyKeE's Avatar
i did mine from the bottom... just let me tell you..... what a PITA!
i would recomend following the write up. i have not tried it that way, but after going through the bottom...if i ever have to change my corners again, i will definetly try taking the headlights out first
