Wet Sanding
When pertaining to paint, there are two purposes;
The first is to provide a surface for a coat to adhere to (could be raw metal to primer, base to clear, adding clear to dried clear, etc).
The second, and the one you're refering to, is to elliminate aberrations in the paint, which could be contaminates or flaws in the paint (typically clear, though it can be done to base coats as well) such as severe orange peel, runs, etc. That being said, you want to use the lightest paper possible to correct the problem, and you may have to work your way to a finer grit, finishing with buffing and polishing (both of which technically have the same effect but at a much finer scale. This, if done correctly will not leave swirls, however, you are removing some material, so you have to be careful not to remove too much. Unfortunately, and this applies to all mass production auto companies, the clear coat from the factory is much thinner than it used to be, so many people choose to add a few coats of clear before beginning this process, so as not to sand through the clear.
-Mike
