Which HID kit?
Old Aug 21, 2005 | 12:11 PM
LS1mtZ's Avatar
Default Which HID kit?
I have been searching for HID's for Camaro's and came across two main company's for HID conversions: Philips and McCulloch Does anyone have any experience with these. Which one should I get? Here's a link with some pics of the two http://www.xenonking.com/gallery1/6000/6000_22.htm
Old Aug 21, 2005 | 04:04 PM
Ling_650vette's Avatar
Hitup DinoZ w/ a PM on here if you want HIDs. He sells kits that I believe are pretty much plug & play.
Old Aug 21, 2005 | 04:30 PM
SporkLover's Avatar
dont waste your time with these kits unless they include HID projector housings. Why would you want to stick an HID bulb designed for a HID projector housing installed in a halogen housing? That creates alot of glare, and "hot spots". A good HID installation should have a nice cutoff line, and Kits dont give you that.
Also....as far as plug and play goes, it is a bad idea to use stock wiring. There are good threads at www.hidplanet.com that describes why, but when a ballast powers up, it pulls a surge of power through wiring that often exceeds stock capacity, however once powered up they run at a much lower rate.
Here is some good reading....
http://hidplanet.com/forums/viewtopic.php?t=3505
Another good thread...
http://hidplanet.com/forums/viewtopic.php?t=2080
A good comparison....
http://hidplanet.com/forums/viewtopic.php?t=8927
And a good place to gather parts.
http://www.hidplanet.com/package.html
Im gathering parts to retrofit Acura TL Bi-Xenon projectors in my car, it will look sweet when finished.
Old Aug 21, 2005 | 04:47 PM
spy2520's Avatar
I thought somebody had a kit out that had a correct pattern for a standard housing. It had a cutoff line. Or atleast they said it did. I cant remember where.
Old Aug 21, 2005 | 04:56 PM
SporkLover's Avatar
By standard housing do you mean a halogen projector housing? I would have to see it to believe it.
You cannot get a good pattern beam with a HID bulb in a halogen housing, unless you are retrofitting a HID projector into a halogen housing. At that point it makes the reflective silver lining in a halogen housing useless
Old Aug 21, 2005 | 05:18 PM
spy2520's Avatar
i dont really remember, could have been BS anyways.
Old Aug 21, 2005 | 07:57 PM
VIP1's Avatar
Copy & Paste Moderator
HID projectors in a Camaro:
https://ls1tech.com/forums/showthrea...ght=camaro+hid
Old Aug 22, 2005 | 11:42 AM
Christos's Avatar
https://ls1tech.com/forums/appearance-detailing/362206-hid-pic.html
