SLP SS Grill - Install and Re-Install?
To save any confusion, this is the grill I'm currently running:
How do I go about installing and then re-installing this grill? It was on the car when I bought it.
Thanks!
I would say to clean around it as those things are sometimes hard to get out and may break. You may also damage the grille, so if you do decide to remove it be carefull.
Chris
Guess I'll leave the grill where it is, and break out my Qtips!
Thank you for the good information.
The push-fasteners I take out with wire cutters
(gently). I was able to reuse them. This fastener
can be found in the Help! blister-pack rack if you
ruin too many of them; they're basically a
"consumable", not expected to last more than the
initial assembly.
Just be gentle and you won't break nuthin'.
Now, I wouldn't have done it just to clean; I had
a project motivation.
I have some additional questions about removing a SLP SS grille from a car. I am buying a used one and need to know how I can access these fastners to remove it from the seller's car. Do I reach up from underneith the car and get to them from the back or do I work my fingers through the grille openings in the front and push them out with plyers or some other tool?
Thanks guys! Buying a used one for $100 as $300+ for a new one from SLP is crazy.
