Shaved Door Handle Kits
Old Jan 13, 2006 | 08:46 AM
Desh98's Avatar
Default Shaved Door Handle Kits
Can anyone recomend a good door handle shave kit? Thanks
Old Jan 13, 2006 | 09:39 AM
ninety9ta's Avatar
There this new kit that was introduced at SEMA this year that is pretty cool. I believe it's called magic touch, however it does not involve nearly as much work as real shaved door handles. I think you just apply over your existing door handles. It look pretty good.
Old Jan 13, 2006 | 10:02 AM
Desh98's Avatar
cool, thanks, I'll look into it.
Old Jan 13, 2006 | 02:00 PM
XxXTransAmXxX's Avatar
http://www.lafranceautoworks.com/
Magic Touch kit....I will be going with it, it's pricy!!! Looks clean though, they do not have a direct bolt on kit for the Fbody right now. However you can go 3 different routes, have a window sensor installed to operate the handle, get the 4"x6" blank and have it worked into the door (which I will be doing since I am repainting the body, because you will need the cut a place for the blank...), or to pay alot of $$$ to have the product made for the car I forget the amouth they told me, but your best bet would be to get a group of guys and go in on it....Basically if you think it is expensive take ur ride to a autobody shop that does mod work, and ask them how much to have shaved door handles put on using a popper, etc... traditional setup, and compare it to thise new setup....
Old Jan 13, 2006 | 02:15 PM
01 Red WS6's Avatar
That looks cool but I don't like the price... Thats per door too. I would want the door skin smooth too so I don't know if that kit would be for me unless I get the window sensor but I would want to see how it looked 1st
Old Jan 13, 2006 | 03:35 PM
meissenation's Avatar
thats sweet, wish i could afford it.
Old Jan 13, 2006 | 03:59 PM
FloridaZ's Avatar
I've alway been one to spend money on things others wouldn't, but....that price is f-ing rediculous.
Old Jan 13, 2006 | 06:20 PM
Reject's Avatar
iunno i still like the traditional **** better, how much lbs's do you need for the door poppers?
Old Jan 13, 2006 | 06:37 PM
Cummins's Avatar
How much $$?
Ling_650vette's Avatar
My buddy was quoted $1000 from start to finish on his Silverado.
Me personally, I'd rather pay a bit more and have it look clean and finished vs this setup. Not to say its bad, but for the money I'd find a better use.
Old Jan 13, 2006 | 07:04 PM
Trojan35's Avatar
Agreed, $700 for two doors? And that's just the parts? I think if I want to drop $1k, I can get something done better than this. Heck, I could even buy those overpriced non-pop-ups for my bird :p
Old Jan 13, 2006 | 07:59 PM
I like the idea of being able to "touch the door" and it pop open like that, just because that's uber cool... and it's different than regular poppers, so it's got the whole "new gadget" coolness about it, but the price does suck.
Old Jan 13, 2006 | 08:07 PM
gtoformula400's Avatar
Love the idea... just wish I had the money LOL
Old Jan 26, 2006 | 02:13 PM
z28hottie's Avatar
is there anywhere that sells regular shaved door handle kits? thats bad *** but i dont like how you can still see where the door handle is
Old Jan 26, 2006 | 07:17 PM
onyxxtreme's Avatar
I've installed a few kits on some trucks, so i have a few hints and tips
definitely get the higher end shavedoor kits, like Autoloc
If you buy the cheap kits out there (the ones that are around $100), you WILL regret it later, trust me. And instead of using the wires to connect the solenoid to the latch, use a piece of metal coathanger. The wires come loose over time.
Dont ever crimp the wires together, solder em.
Make sure you get rubber boots for the solenoids.
And last, dont pay a body shop tons of money to shave the handles off your Fbody. These cars are the easiest to shave, since all you have to do is glass em. Might take longer than welding would, but anyone can do it. There's a million fiberglass how-to's out there, on sites like s10forum.com, etc
Old Jan 26, 2006 | 08:16 PM
Reject's Avatar
how do you fill in the handle first, do you like get an old peice of the door then fiberglass it over or what?
Old Jan 27, 2006 | 01:10 AM
00TAProject's Avatar
The intensions are good, but I agree with a few others here, i would rather have a clean smooth look......Not a bad idea....Just not for our cars.....
