Sponsored by: DashLynx
Passenger seat rattles constantly!
Old 01-13-2006, 03:46 PM
99sprayjunkie's Avatar
Default Passenger seat rattles constantly!
Anyone have this problem? Is there a simple fix, as im ready to rip the damn thing out!(dead weight right?) It seems like maybe a bad hinge or pin?,i dont know.Car is A4 w/ poly tranny mount,which im sure contributes a bit.No sub frames yet, but theyll prob. make it worse.Any ideas greatly appreciated.
Old 01-13-2006, 03:50 PM
ssjunkie's Avatar
My seat shakes also! Every now and then I reach over and stop it which helps for all of 3 seconds. the seatbelt makes noise when it shakes...ive considered just keeping the passanger belt fastened but have never tried it.
Old 01-13-2006, 04:36 PM
BURN'EM's Avatar
I'm with you! The thing is constanly moving and making noise. I cheated and placed a flat metal bar in the back under the leather on each side . Gave it some weight to stay leaned back
Old 01-13-2006, 04:39 PM
02silverbullet's Avatar
My car does the same. I need an alignment, which makes the car shake sometimes. The seatbelt buckle like to make the most noise. What i do is reach over and buckle the seatbelt as if someone would be sitting in it. Rattle stops.
Old 01-13-2006, 08:17 PM
kazfan30's Avatar
DAMN.....I thought i was the only one?????? the passenger seat rattles like a son of a bitch
Old 01-13-2006, 08:37 PM
CashMoney's Avatar
I lean mine back and it stops..
Old 01-13-2006, 08:42 PM
sleepinghawk's Avatar
My car does the same,but I too found that by leaning the seat back more, it helps.
Old 01-13-2006, 09:11 PM
FlipFlopWS6's Avatar
my seat rattles too. I just recline it more and normally it goes away... now my seat belt is hitting the side of the seat, so if im driving and getting irriated i just buckle it to keep it in one spot.
Old 01-13-2006, 09:23 PM
DAKMOR's Avatar
Just rip that sucker out!
Old 01-14-2006, 01:23 AM
Formula-T/A's Avatar
Mine does it like a SOB, I usually knock the f--ck out of it and it stops. I will try leaning the seat back.
Old 01-14-2006, 10:25 AM
keliente's Avatar
Being out of alignment won't make the car shake.
My pass seat shakes too. I am just careful to not set any bottles of soda in it
Old 01-14-2006, 10:35 AM
Silver02TA's Avatar
mine used to rattle a ton until i balanced my wheels, stopped most of the vibrations
Old 01-14-2006, 10:41 AM
Rescue Ranger's Avatar
thats really funny, because i never thought much about my rattling seat except two of my good friends are 320lbs and 280lbs.. i'll try reclining it a notch definately.
Old 01-16-2006, 02:41 AM
Wow who'd a thunk it. Maybe someone will come up with an easy fix since so many of us seem to have this problem Thanks guys,at least i know im not the only one.
Old 01-17-2006, 12:19 PM
SilverV6Camaro's Avatar
Mine does the same thing. It's usually slid all the way back from people sitting in it, but when I slide it forward a notch or two it stops. Drove me crazy until I figured it out. Now if I could only stop the t-top from tapping over bumps...
Old 01-17-2006, 01:21 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
I recline it a little and put the seatbelt on it...mostly stops it.
Old 01-17-2006, 04:09 PM
evilbadz's Avatar
Mine was doing this a lot too, so I tried to find out why. Turned out the bolts that were holding the seat to the sliding rails were loose. I tightened them up (was a pain since it's such a small space), and it hasn't rattled since.
Quick Reply: Passenger seat rattles constantly!
