polishing aluminum
Old Jan 29, 2006 | 01:57 PM
wilwhite2kss's Avatar
Default polishing aluminum
I tried to polish my throttle body yesterday, but it came out like crap. What am i doing wrong, and am i using the right stuff? I pulled it off ,sanded all the residue and the surface to make it somewhat smooth. After that i took a dremmel with some metal polish an went to town. I got a little shine and alot of pivets. I have seen other peoples polished parts, and they came out like chrome. What am i doing wrong ,or did i skip any steps? Tell me how to do it the right way. (without paying for it )
Old Jan 29, 2006 | 04:48 PM
FLA02TA's Avatar
Well, what polishing compound did you use in the final stages? Might not be the right one maybe?
I'd venture a guess that it can't be much different than the process the guy used to polish calipers. Aren't TB's forged with iron? They look like they are.
Old Jan 29, 2006 | 05:03 PM
dementia's Avatar
From the sound of it you skimped on the most important step. Sanding. You said you made it somewhat smooth and then it had pivots when you polished it. In order to get a good mirror like finish you have to sand that thing down to be perfectly smooth. Start with big grit and work your way to 2000 grit paper if you're doing it by hand. After sanding it should look really good as it is and be perfectly smooth to the touch as well as visibly smooth. After that then you can start with the polishing compound. Good luck and be patient.
Old Jan 29, 2006 | 07:18 PM
Phoenix 5.7's Avatar
i have used mothers mag and aluminum polish with success. just rub on, rub off
Old Jan 29, 2006 | 07:28 PM
johnebgoode's Avatar
What grit sandpaper did you use? Try starting out with 1000 then 1500 and then 2000. Then polish it out. Should be fine. Mothers Mag polish is what I've used in the past with great results.
Old Jan 29, 2006 | 07:52 PM
steveo346's Avatar
Talking
ok here it goes newbie....j/k....i have polished a couple of stock ls1 throttle bodies in my time....here are some steps
1. you remove the throttle bodyfrom the intake and them remove all the sensors and crap
2. you then begin to wet sand it with a 220 frit to get all the rough areas...amke sure you apply alot of pressure...and dont be afraid to be sanding it for a while in the same area so you can remove any real rough spots
3. then go on to a 320grit, 400grit, 600grit, 800grit, 1000grit, and then finish off with a 1500grit....remember to wet sand during all of these steps....
4.dry and clean the intake and make sure it no longer has aluminum residue from the sanding on it...
5.start to polsih it with your choice of aluminum polish...i make my own but if i did not i'd prolly go with mothers billet polish...
6. once you've given it a couple of coats of mothers and wiped it off with a 100% terry cloth towel...admire your beautiful work!!!
7. final step...and this is a must...take alot of pics and post in here of your work!!!
i also polish the butterfly on the TB as well and the spring too!!
here's what it will look like...pics below
Attached Thumbnails polishing aluminum-my-egr-blockoff-plate.jpg   polishing aluminum-my-ls1-motor.jpg   polishing aluminum-my-polished-ported-tb.jpg   polishing aluminum-my-ls1-enginee.jpg   polishing aluminum-my-ls1-engine-stb.jpg
Old Jan 29, 2006 | 09:39 PM
luckyou03's Avatar
check this out
Polishing How-to
Old Jan 29, 2006 | 10:00 PM
LANDONZ's Avatar
I polished mine with a dremel kit I bought at Kmart especially the little blue disk thats in there.. :thumbup: and some mothers mag and aluminum polish
Old Jan 29, 2006 | 11:11 PM
Super Speed's Avatar
Wow steveo that looks absolutly amazing!
Old Jan 30, 2006 | 05:00 PM
steveo346's Avatar
thanks man...it takes me alot of hard work and time for me to polish up all my stuff and i do all the work myself...it feels good when someone gives you a comment and compliments you on your job well done
Old Jan 30, 2006 | 11:16 PM
RrCoX22's Avatar
Dude is that the stocker..... holy shiot.
You just made this next weekends project for me!
Old Jan 31, 2006 | 11:38 AM
LvDemKings's Avatar
I'll be starting mine this afternoon.
Old Jan 31, 2006 | 01:55 PM
~JOSHUA's Avatar
Default You need to sand first
Old Jan 31, 2006 | 02:05 PM
monkey man's Avatar
Originally Posted by FIREHAWK#608
damn FIREHAWK#608 u always rain on my parade...every time i show something of mine that is decently polsihed you always post your pics and make me feel like **** ....haha but its kool your engne does look freaking sweet
oh bythe way im steveo346 but logged in on a friends comp
Old Jan 31, 2006 | 02:11 PM
~JOSHUA's Avatar
Hey steveo346!- Sorry to rain, just trying to juice him up on what's possible. Your deal isn't bad at all, you just need a lil' more time...
Old Jan 31, 2006 | 09:18 PM
HotWhipT/A's Avatar
I got a question. How am I suppose to sand the hard to get areas that you can't really get with the sand paper?
Old Jan 31, 2006 | 10:54 PM
camaroextra's Avatar
i got bored today and started to polish the loudmouth exhaust i bought today. pic later
Old Jan 31, 2006 | 11:24 PM
RAIDER's Avatar
firehawk that **** looks awesome, but what i was wondering is, is everything pretty much covered in this thread or is there a step still missing? thanks
Old Feb 1, 2006 | 08:28 AM
~JOSHUA's Avatar
Sand smoother and smoother, polish by hand or put some power to it. If you can get a drill and buy some attachments from Eastwood==>(sponsor) you'll cut out a lot of elbow grease. If anyone wants help on what to buy, pm me and give me your phone #. I'll call you back and we'll both go to the website, and I'll show you exactly what you can order to make things easier. -Joshua
Old Feb 1, 2006 | 10:16 AM
2002_Z28_Six_Speed's Avatar
Damn! That's pretty awesome! Whoever did all that hasn't been out of the garage for awhile though!
