problems with halo fitment
also, are u using the brackets that came with the light, or the stock brackets? i've heard the brackets only make a difference in sturdiness (sp?), but maybe there also seems to be a conflict in measurements as well, in ur case?
just a few questions to put out there to get the mind goin...
Don't worry man, everybody who has halos, is in the same boat as you. IDK if its quality control or what, but they all suck. You have to find a happy medium of looks, and light shining on the road properly. Good luck.
You said your stocker was like that too? That just tells you that there is nothing wrong with the halos, but with your car instead. Are you the original owner? If not, I'd say there is a good chance the car was hit and someone didn't put it back together right.
I mean mine don't fit perfect either, but damn....the position of the headlight in relation to the fender is waaaaaaaaaaay off! When I first looked at your pictures before reading what you had to say, I thought for sure you were going to ask how to get the headlight all the way in position...because that's how mine looks like before the one adjustment screw goes throught the hole in the bracket that remains on the car, and before those locking tap things slide into position.
thats about the only other thing i can think of... then again, if others are havin the exact same problems, maybe it *is* the lights u got. i got mine from hawksthirdgen.com and they fit just fine.
sorry to hear about this prob though...i just dont feel like lettn somethin this simple go with an excuse like "must be the aftermarket light" or "someone may have wrecked the car an not put it back together properly"
exhaust all options before givin up
also try puttin the old headlights back in and see if they look the same as before u took them out. if not, then u know ur just missin a step...
BOSS APPROVED!
