removing key hole in back
Anyways, you could use bodyfiller to fill the hole. I would grind it rough and fill it with either standard bodyfiller or a product like Duraglass(fiberglass filler). Then sand, finish and paint. If you don't have any autobody experience don't try it.
nikeboy313 has a good point. Filler will shrink when thick. I would get it almost perfect and then let it set a couple of weeks or more if you have the time, preferably somewhere hot. If you do not it will shrink back and you will see a lake there.
Good Luck!!
p.s. about my "removing the key hole"....how do you take off the key hole is what i was askin? sorry
This has been the hack method for filling rust holes up here in the rust belt for eternity. The only reason it does not last on rust holes is rust never sleeps. No such concerns on a SMC panel.
I filled in my camaro letters on that panel this way(except there were no actual holes). I took my time and they did not shrink back. I should of filled the keyhole too. I have never used it, for all I know my key does not fit??
Anyways I thought it was just funny about removing a hole
