speaker covers rattling.
Old Jul 3, 2006 | 12:09 PM
squall01's Avatar
Question speaker covers rattling.
does anyone have any ideas on how to stop my rear sale panel speaker covers from rattling? it makes my stereo sound like *** and i need some ideas on how to fix it.
thanks,
bill
Old Jul 3, 2006 | 12:13 PM
wzup1000's Avatar
I bought some silicone and put a small bead around the edge that touches the plastic panel. Works great no rattles...
Old Jul 3, 2006 | 12:48 PM
squall01's Avatar
what about to stop the sail panels from pulling loose form the body? i always have to push them back into place but they seems to always work loose.
Old Jul 3, 2006 | 01:13 PM
JoeyAnderson's Avatar
Mine do this, too. I've experimented, but haven't come up with a solid solution yet.
That'd be great, but then I couldn't remove the cover(s) when/if I wanted to...
Old Jul 3, 2006 | 02:54 PM
squall01's Avatar
well, you could pry them off if you needed to change a blown speaker or something. it's not like super glue. i'm gonna try the silicone idea.
Old Jul 3, 2006 | 04:35 PM
wzup1000's Avatar
no, I took off the cover, put a bead around the edge of the cover, let it dry, then reinstalled it. I cant see the bead unless I take the cover off, it allows me to take the cover off when I need to, and it doesnt rattle anymore. As for the covers coming loose on their own I guess you could check to see if you have broken tabs or try gently bending the tabs to make it where it will make a secure fit and not rattle loose, but with the bead of silicone it will not rattle anymore so it probably wont come loose anymore... hope this helps, good luck...
Old Jul 11, 2006 | 12:36 AM
black99ssm6's Avatar
i had to take the speaker covers off after i installed my system. the best solution that i found was to get some of the 3m emblem adhesive tape and wrap some around the tab that holds the cover in place. It's been almost a year and no rattles, the door speakers are another story though
Old Jul 11, 2006 | 12:38 AM
ryanfx's Avatar
in my 93 firebird I jammed a penny in the speaker cover.. that stopped it as ghetto as it was =D
Old Jul 11, 2006 | 02:23 AM
97MysticZ's Avatar
What's a Sticky?
The door speakers are easy to get to stop rattling. When I had my door panel off changing my speakers, I just JB welded the whole speaker cover on, no rattles and it doesn't matter because you have to take off the door panel to mess with the speaker anyways.
