Window Tint removal
Old Jul 30, 2006 | 05:22 PM
ironexecutioner's Avatar
Default Window Tint removal
I was wondering if you guys had a suggested best way of removing window tint. I just bought a 99 SS and the windows are tinted, I live in PA and they will make me remove it at some point just looking for suggestions on how to remove it and not have it look like @$$. Thanks
Old Jul 30, 2006 | 05:29 PM
Beasst8's Avatar
I used a hair dryer to heat it up and it peeled right off. just be EXTREMELY CAREFUL WITH THE BACK GLASS AND THE WINDOW DEFOGGER. Good Luck
Old Jul 30, 2006 | 05:30 PM
KrazyDan's Avatar
I just pulled mine off. Then sprayed a water/soap solution and went over what ever stuck with a razor blade.
Old Jul 30, 2006 | 05:31 PM
blown 346's Avatar
Depending on what quality the tint is, you might have a little trouble with it.
If the tint is te purplish color etc it is low grade tint and 95% of the time it peels off in little pieces. That can take hours to get off.
Normal decent tint, just grab the edge of it at the top of the window and peel slowly, just continue to do so the whole sheet will come off.
Next you have to remove the glue, a razor blade and some goo gone or something similar wil help out.
Duffster's Avatar
LOTS OF WINDEX or ammonia/water solution. CAREFUL w/the ammonia!
Try like 5 parts water & 1 part ammonia.
Old Jul 30, 2006 | 05:56 PM
1999 SS's Avatar
vinegar & warm water
Old Jul 30, 2006 | 05:59 PM
smg267's Avatar
Man up and use gas. THat is the only thing that got it off my car i used windex and that white bathroom cleaner stuff that worked a little bit. But just get the paper towel a little damp and just scrub the **** out of it. Finish with windex. I would def try the whole hair dryer thing before the gas of course
Old Jul 30, 2006 | 06:11 PM
Mr Incredible's Avatar
Google "removing window tint" and see what you find.
Old Jul 30, 2006 | 08:57 PM
INMY01TA's Avatar
Do not use a razor blade to get the glue off. It will scratch the glass. Use a razor just to start the tint in a corner and just pull it off. I used a portable Shark steam (like this) cleaner to get the glue off. Worked really well.
Old Jul 30, 2006 | 09:39 PM
LS1 Terror's Avatar
start on the corner of the window and work inward with a razor blade. try to take big pieces off at a time. once all tint is off soak the glass with window cleaner and start takin off glue left behind from the tint. this might take some time so take your time. then just rinse glass with water
Old Jul 30, 2006 | 10:19 PM
Camaro Z's Avatar
I tint windows, and the best way is to get a corner loose and just rip it off. Then use a razor blade (I have solution called tint-off that is amazing) but you can use anytype of realitively potent cleaner to help it loosen up.
