t-tops anyone tint them
thanks
It woukld follow that the side windows..if tinted would have the same problem and Ive never heard of a side window shattering because of tint
The concept goes somthing like this..the extra tint helps the glass to hold onto more heat thereby making it crack
you'll spend more on tint then you will on the shades...EBAY is your friend
however i have tinted t-tops at my work but never had a problem...then again michigan isn't nearly as hot or sunny...just humid as a mother effer!!!
The tinted glass on the t-tops absorbs the heat. Tint that is applied at a shop is designed to reflect the heat. With the two together it only reflects light back into the glass, double the heat source. But then again its your car, do whatever you want to it. Just letting you know what COULD happen.
they work great and keep the leather cool. all my other windows are 15%. i say go for it! and i can still see out of them perfectly fine if you are wondering
