LED backseat lights on a convt?
Old Aug 20, 2006 | 08:53 PM
firebird5134's Avatar
Default LED backseat lights on a convt?
I have a convertible so obviously I dont have a dome light instead have two bulbs on the side. Anyone know what bulb size they are? Im looking to replace them with LED's. Are they 212 bulbs?
Old Aug 20, 2006 | 11:49 PM
kws87's Avatar
thats a good idea, I would also like to know
Old Aug 21, 2006 | 01:18 AM
whitedevil's Avatar
I had a 95 Z28 Vert, and when I went to change mine to green, or some other color, to my suprise, they are soldered in! I would just solder LED's into them.
Old Aug 21, 2006 | 07:17 AM
WhiteBird00's Avatar
Ungrounded Moderator
Parts catalog lists them as a #561 bulb.
Old Aug 21, 2006 | 09:37 AM
I took it apart last night. Its a bulb that has a wire loop on each end and then the socket hooks into that loop. Why wont Pontiac just use the same bulb as a dome light
Old Aug 21, 2006 | 10:54 AM
StrobinSS's Avatar
the loops are what I have for my domelight
Old Aug 21, 2006 | 11:38 AM
Proximo's Avatar
i'd also like to know
Old Aug 21, 2006 | 11:45 AM
The #561 bulb is a standard bulb used in dome lights and courtesy lights. It is a T-3 Rigid Loop bulb producing 12 candlepower at 12 volts. LED replacements are available in various colors on eBay and other web sites such as superlumination.com.
Old Aug 21, 2006 | 02:54 PM
oh awesome thats the site was placing the order through. Thanks guys ill post pics up when i get them installed!
Old Aug 21, 2006 | 02:58 PM
TORCHD 02 TA's Avatar
they are 212-2. do a search under my name of the new LEDs i put in
Old Aug 21, 2006 | 03:02 PM
No, they're not. Although the 561 and the 212-2 are physically interchangeable, the 212-2 has only half the output (6 candlepower) and is not a recommended replacement for the original 561 installed from the factory.
Old Aug 21, 2006 | 03:33 PM
you talking about this?? i Have never seen these yet i am sure they exist.
this is what i used
the one that i am using will work on your car. the advertise it as a 212-2 / 212-4 they are the same.
look at the thread i made with the lights i bought
https://ls1tech.com/forums/showthrea...t=ls1obsession
Like i was sayign the 212-2 / 212-4 will work on his car.
Old Aug 21, 2006 | 03:39 PM
They might, they might not. The 212-2 is an end-cap design made for the dome lights in coupes. The 561 is a rigid loop design (hooks on to the lamp contacts at both ends like your first photo) made for the side interior lights on convertibles. Usually the contacts in the lamp can be used either way - but not always so why buy something different like the 212-2 when the correct bulb is available? (The LED version 561 just like your photo is available in at least three different colors.)
Old Aug 21, 2006 | 04:17 PM
then i would check ebay.... or go where i bought mine. v-leds.com
Good Luck
Old Aug 21, 2006 | 06:44 PM
this is what i used
That is exactly whats in my car now! Any idea where you found those?
Old Aug 21, 2006 | 07:47 PM
which one???
Old Aug 21, 2006 | 11:31 PM
The one on top. The socket has two little hooks that hook onto those loops. I cant really find them online. I may just try the ones below it and rig it in.
Old Aug 22, 2006 | 06:58 AM
I found the 561 LED replacements at superlumination.com. On the home page click on the dome light link (3rd column, 2nd row). On the next page scroll about half way down and you'll see the 561 bulbs in white, blue, and red for $7.99 each.
Old Aug 22, 2006 | 09:05 AM
Those are it! Ive dealt with them b4, great company. Thanks everyone ill post pics when they come in!
Old Aug 22, 2006 | 01:44 PM
hey if you want to see the blueish color ones, do a search on my name and find the post new map and dome lights. they look nice
