How do I make this black again?? *pic*
Old Nov 6, 2006 | 08:22 PM
kevinclark09's Avatar
Default How do I make this black again?? *pic*
This strip of metal/plastic/whatever is faded horribly. The owner before me took the car to work and it sat in the sun all day long and now this peice is faded like crazy. We have tried cleaners wax and metal polish, but so far none of them are working. What are some suggestions from you guys as to how I should make this peice look better? Any help is welcome, and thanks in advanced.
Old Nov 6, 2006 | 08:25 PM
Z28_DAD's Avatar
looks like it may need some paint.
Old Nov 6, 2006 | 08:27 PM
how much would it cost to paint it, or better yet, could i do it myself?
Camaro Ryder KV's Avatar
x2!!!!
Old Nov 6, 2006 | 08:30 PM
01sscam's Avatar
Man-Crush Warning
I'm thinkin paint it.
Old Nov 6, 2006 | 08:32 PM
presto_z's Avatar
i gotta paint mine to
Old Nov 6, 2006 | 08:33 PM
onefastbird95's Avatar
I am pretty sure there is something out that is called "back to black" but not sure who makes it or what it is safe to put on... If I see it i'll let you know.
cooltc2004's Avatar
You could mask everything else off and spray it if you'd like. Hard to tell from the picture, but it almost looks like its bare metal color? Kinda looks good bare metal.
Old Nov 6, 2006 | 08:39 PM
kerryt1's Avatar
"Back to black" would work just fine.......but it's only a band-aid on a broken arm. It'll be great if you put it on with every wash, but it'll eventually just wear off. Paint is the only fix, and I think you could probably pull it off yourself with a rattle can, if you did meticulous prep work and maybe some color sanding afterward. You might dig around on PT.net, there are a ton of guys who've painted stuff with a can and had great results.
Old Nov 6, 2006 | 08:44 PM
so do you guys think i can take this peice off and paint it while its off?
Old Nov 6, 2006 | 08:46 PM
Tainted's Avatar
probably the bottom rocker things but that t-top center piece doesnt just bolt on I dont think...maybe im wrong though ive never looked at it that much
*KANDY SS*'s Avatar
Restricted User - Non Spon Soliciting
mothers makes it
Old Nov 6, 2006 | 08:53 PM
Magnet's Avatar
im interested too, mine looks good now but i think its not gonna last too long in this florida sun..its the same metalor whatver thats on the little triangle by the dooor i believe..those might need it too
Old Nov 6, 2006 | 08:56 PM
Phoenix 5.7's Avatar
the center bar is screwed on, but also sealed on with some sort of glue. i already tried taking mine off for something. have u tried wet sanding it?(might be ahrd to do on hte car) maybe u can sand down through the gray sun damage down to black.
Old Nov 6, 2006 | 08:58 PM
thats what i was thinking but since its metal i dont see why it would be black all the whay through. does anybody know if it is black all the way through or just painted?
Old Nov 6, 2006 | 09:07 PM
i think its plastic, and yes, i would imagine, to the post below this one
Old Nov 6, 2006 | 09:08 PM
so sand it like i would the rear filler plate, then polish?
Old Nov 6, 2006 | 09:11 PM
Marc 85Z28's Avatar
Is it a grainy porous plastic? PEANUT BUTTER! Really! Just get some creamy peanut butter, rub it on kind of thick and let it sit for 10-15 minutes. Then rub it off. It works much better than the Back to Black stuff, and is near permanent. I know it sounds crazy but just try it...
Old Nov 6, 2006 | 09:13 PM
haha dang. that sounds cheap and easy, i'll have to try that...
Old Nov 6, 2006 | 09:14 PM
Flamin' bird's Avatar
Before you paint it please try this because it worked for me. Get either Mother's Body scrub or 3M Fine Cut Rubbing Compound. It worked wonders on my sail panels, boyfriends and his brothers. They are nice and shiny now!
