Blue lighted gauges out....
Old Nov 11, 2006 | 08:41 AM
SOMSS's Avatar
Default Blue lighted gauges out....
I have grown weary of not being able to see certain parts of my dash gauges (blue). To remedy this I am changing the dsh color to pure white. Cost will be about $29 shipped. The dash will look like this:
Old Nov 11, 2006 | 09:51 AM
kraaazymike's Avatar
I don't know that those gauges will fix your troubles. The pic shows dead spots in the lighting. Almost like you'll be keeping the same problems but in different colors
Old Nov 11, 2006 | 07:02 PM
6LITEREATER's Avatar
Yeah, do NOT ORDER LEDS or you will still have hotspots... You want pure white Xenon 194 BULBS which you can get off ebay cheap...
$29 is ridiculous for 5 LED's OR bulbs regardless...
I used blue film behind my gauges and white bulbs to get this effect with no hotspots:
Old Nov 11, 2006 | 07:16 PM
SmokedOutZ28's Avatar
Can someone clearify what are "hot spots"? I ordered Led's to make my cluster lighting look white again after ordering GMS's 200Mph Speedo overlay. The led's i bought made it blue which was better then the green it was, but if i could get it back to the stock lighting that would be great.
Old Nov 11, 2006 | 09:50 PM
The Black Pearl's Avatar
Notice in the first picture where down by the 150 its dim? They are just places where the light will be brighter that others..
Old Nov 11, 2006 | 09:54 PM
Oh ok thanks. I ordered the bulbs listed above so hopefully it will go back to stock again.
Old Nov 11, 2006 | 10:41 PM
Snuffles's Avatar
If I remember correctly, the GMS cluster has a blue tint to it.
I did the same thing as you and the hyperwhite LEDs didn't fix anything.
When I had the cluster out I looked through the bulb sockets and it was still blue.
Let me know how those Xenon bulbs work out.
Old Nov 11, 2006 | 11:06 PM
Even the stock cluster will have a blue tint to it guys... That's how the factory got green (crappy yellow light bulbs + blue film on the cluster itself = green) SO the best you can do is get hyperwhite Xenon bulbs (which emit PURE WHITE LIGHT) and your cluster will be white with a blue tint.
The GMS gauges are made to match the factory so you'll get the same thing...
Old Nov 11, 2006 | 11:10 PM
Yes it does but according to Gms and there website it's not enough of a tint to affect factory apprearing lighting. I was told that my green color was due to old bulbs turning yellow with age so i put in the leds and got blue, figured it looked better then the green so i stuck with it but if this could make them a lighter blue or maybe white again i would be happy. Heres what it looks like at night with the hyperwhite leds
The only hot spot i have is around the oil pressure gauge and slightly around the fuel level gauge.
Old Nov 11, 2006 | 11:24 PM
Snuffles's Avatar
Going from stock bulbs to the LEDs was a major improvement with my cluster.
However, I have a hot spot around the oil pressure gauge too.
Old Nov 12, 2006 | 12:22 AM
Brian2006's Avatar
No problems with mine either. Just make sure you get weldx5 LEDs to spread out the light evenly:
