new wheels
Old Jan 22, 2007 | 01:33 PM
gonefishn1212's Avatar
Default new wheels
will putting new 17" wheels (stockers are 16") screw up the actual odometer readeing and the actal MPH? if is how do i go about calibrating the car to 17s?
Old Jan 22, 2007 | 01:36 PM
Tainted's Avatar
gotta have the pcm tuned and yes it will.
http://www.f-body.org/gears/
Old Jan 22, 2007 | 01:48 PM
LT1MAN's Avatar
i believe if you use a smaller sidewall tire then it counters the different diameter wheel.
Old Jan 22, 2007 | 02:11 PM
Brian2006's Avatar
use a 40 sidewall tire and it'll be fine. Other than that it's nothing major
Old Jan 22, 2007 | 02:12 PM
BitViper's Avatar
True Dat! go to 17" wheels and 45 series rubber the outside diameter is the same as the 16's
Click teh "2002 Pewter Z28 (pic)" link in my tag to see
Old Jan 22, 2007 | 02:13 PM
texasreb18's Avatar
lt1man was correct. a smaller sidewall with the bigger rims will have the same overall diameter as the stock rims with a bigger sidewall. you can use a tire calculator like the one here to see if the new combo will be any different and how much it will affect your speedo
Old Jan 22, 2007 | 06:58 PM
kevinclark09's Avatar
Brian's advice helped me from getting completely screw over with the tires for my new rims. Thanks again man.
Old Jan 22, 2007 | 09:24 PM
pwterz28's Avatar
factory size tires 17 and 16 are the same height
