Push Start Button
Old Oct 17, 2007 | 04:04 PM
  #81
therobman's Avatar
i have a remote start and i can either use the key to start it or the remote i just think the burttons kinda cool and just want to know if it will make my remote start not work
Old Oct 17, 2007 | 04:42 PM
  #82
blackbyrd's Avatar
i dont think so all you are doing is disconnecting the switch part out of the key silenoid and adding the switch, so i would think you would be fine
Old Oct 17, 2007 | 05:06 PM
  #83
1SLO6's Avatar
http://cgi.ebay.com/ebaymotors/JDM-S...spagenameZWDVW
This price is to good to be true....
Old Oct 17, 2007 | 05:18 PM
  #84
1SLO6's Avatar
Alright understand wiring harness but does #2 wire go connected to the pink wire under dash or where? I see that the #2 wire goes connected to steering wheel accessories......re-confirmation needed Thanks.
Old Nov 5, 2007 | 04:03 PM
  #85
therobman's Avatar
k i went to do this mod today and this is what i found theres wires already tapped into the red,pink,yellow,and brown wires they go to my aftermarket remote start if i do this mod like they say will it mess up my remote start hes a crappy pic to kind show what i mean
Old Nov 5, 2007 | 05:11 PM
  #86
therobman's Avatar
can anyone help me
Old Nov 5, 2007 | 07:27 PM
  #87
therobman's Avatar
Old Nov 6, 2007 | 02:27 PM
  #88
zfastss's Avatar
See post #7 on the first page. In the write-up, it shows the yellow wire being cut. Instead of cutting this wire, just splice into it. This means that you aren't actually changing any of the ignition wiring, just adding to it (ie your key will still work if you wanted to use it). I highly doubt that anything will happen to the remote start since the wiring is not changing as I mentioned before, but there's no way to be 10000000% sure unless you try it.
Old Nov 6, 2007 | 03:27 PM
  #89
iwantatransam's Avatar
Ok, I've got an Idea, I want to do the push button start thing but keep the car looking very stock, use the cig lighter as the button. I've seen a vid on YouTube (Here) I'm thinking i would have to replace the cig lighter with just the hot plug (so the lighter doesn't stay in the down/starting position) how would I do this?
Old Nov 7, 2007 | 08:34 AM
  #90
94_LT1_Z28's Avatar
If I were gonna do this mod, that's what I'd wanna do... That way if you don't have alarm system, it get really confusing for whoever is trying to steal your car.
Old Nov 26, 2007 | 05:31 PM
  #91
Xray's Avatar
I like Range Rover push button start style once push and after 2 second engine will start
Old Mar 29, 2008 | 03:40 PM
  #92
bandit98's Avatar
This is probably going to be another one of those things that I do that no one I drive around thinks is cool, except me. Lol
Old Jun 3, 2008 | 02:50 PM
  #93
QWIK Z of OP's Avatar
^^ lol
Old Jun 3, 2008 | 03:04 PM
  #94
Ryan33187's Avatar
I'm sorry but I would rather start my car this way... anyone know how to install one of these?
On topic I think the push button thing would be awesome if you didnt have to put the key in and it was like the benz style as previously stated.
Old Mar 22, 2011 | 02:11 PM
  #95
xl1200r's Avatar
I know this is an old-*** thread... but what is the purpose of the relay that gets added in? What does it do? If I were to use a momentary toggle switch instead of a button, would I still need the relay?
Old Mar 22, 2011 | 09:09 PM
  #96
InsaneAuto86's Avatar
if you dont use a relay you will burn out your switch very quickly
Old Mar 23, 2011 | 07:33 AM
  #97
xl1200r's Avatar
So is it the relay that's actually doing the 'work' and the switch/button is just telling the relay what to do?
Sorry - I'm a zero when it comes to electrics.
Old Mar 23, 2011 | 08:14 AM
  #98
MTBSully's Avatar
http://electronics.howstuffworks.com/relay1.htm
Old Mar 23, 2011 | 08:42 AM
  #99
MeentSS02's Avatar
Kleeborp the Moderator™
Pretty much...you use a relay so that you can put a switch in a high current circuit without needing a huge, beefy switch.
When wiring in a push button starter on these cars, you have to tap in to some 12 gauge wiring - I'm not sure how much current flows through these wires during startup, but they wouldn't be 12 gauge wire if it wasn't required, and that size of wire can handle a fair amount of current. If you tried running that current through a switch like the one from a Honda S2000, you'd probably fry it in a big damn hurry. If you use the switch to activate the relay instead, the relay takes all of the load, but you still retain the functionality of the switch without having to make it huge.
Old Mar 23, 2011 | 09:16 AM
  #100
i'm sofa king's Avatar
i bought my 2002 Camaro SS LE with the push button start already installed. its wired up so the key has to be on, then you push the button and boom. however the key switch will not start the car.
how hard would it be to switch my current push button (ignited performance, non illumnited http://cgi.ebay.com/ebaymotors/Engin...item56433e25a4 ) to a honda S2000 push button?
all i really want to do is change out the button, not the wiring or anything else. the text is starting to wear off the current button.
