Push Start Button
Old Mar 23, 2011 | 09:23 AM
  #101
MeentSS02's Avatar
Kleeborp the Moderator™
If you've already installed a push button, it shouldn't be that hard to change the button...you'll just need to figure out which pins do what and wire accordingly.
Old Mar 23, 2011 | 09:40 AM
  #102
BOBS99SS's Avatar
Captain Double Post
Anyone got pics of where they mounted there's,?I think its a cool mod,
Old Mar 23, 2011 | 09:47 AM
  #103
MeentSS02's Avatar
If you cross your eyes and then relax them, the push button in the pic below will jump out at you:
Old Mar 23, 2011 | 10:05 AM
  #104
ssteven's Avatar
Mine.............
Old Mar 23, 2011 | 11:10 AM
  #105
i'm sofa king's Avatar
ok, cool.
i didnt install it, so anybody know where i could get a wiring diagram for it?
does the Honda buttom have any wires off the back, or do the wires plug in? i guess i should pop mine off and check it out.
Old Mar 23, 2011 | 11:18 AM
  #106
MeentSS02's Avatar
You'll need a plug to interface with the S2000 engine start button...a good portion (if not all) of the info you need is here:
https://ls1tech.com/forums/appearanc...t-mod-how.html
Old Mar 23, 2011 | 11:24 AM
  #107
ssteven's Avatar
I have a spare s2000 button if anyone needs it. Get a relay and your all set..
Old Mar 23, 2011 | 08:09 PM
  #108
Detoxx03's Avatar
Originally Posted by ssteven
Mine.............
that looks really clean. where did you get the shifter from?
Old Mar 23, 2011 | 08:50 PM
  #109
ssteven's Avatar
Shifter is a trailblazer ss shifter. Ebay $65
Old Mar 23, 2011 | 08:59 PM
  #110
Black94Z28's Avatar
Hmmmm...nice little mod for if I ever finish my other mods...Looks good everyone!
Old Mar 23, 2011 | 10:55 PM
  #111
Detoxx03's Avatar
Did you need a adapter or anything or was it just plug and play?
Old Mar 24, 2011 | 02:57 PM
  #112
how much for the botton? does it have the plug or anything on the back of it?
Old Mar 24, 2011 | 03:50 PM
  #113
ssteven's Avatar
You need a 3 pin plug....one from a computer hard drive or CD rom is a perfect fit..
Old Mar 24, 2011 | 04:52 PM
  #114
cool. my buddy works for ISD (wal-mart HQ IT dept) so maybe i can get one from him.
or is that a cheap thing to get from radio shack?
Old Mar 24, 2011 | 07:45 PM
  #115
ssteven's Avatar
Elcheapo.... Everyone has a spare CD rom drive somewhere.
Old Mar 24, 2011 | 08:27 PM
  #116
Black94Z28's Avatar
Cant wait to install it...my first interior mod...well second if you count the Autometer gauges
Old Mar 24, 2011 | 08:44 PM
  #117
ssteven's Avatar
Mailed the switch today.
Old Mar 24, 2011 | 08:47 PM
  #118
Black94Z28's Avatar
Sweet, my next day off is next thursday, be cool to install it if the weather is nice. Thanks again buddy!
Old Mar 24, 2011 | 08:51 PM
  #119
ssteven's Avatar
Use a small round file to wobble out the hole of the cig lighter. The switch isnt quite round, it has weird notches. Once in it locks with little clips.
Old Mar 25, 2011 | 02:47 PM
  #120
zfastss's Avatar
i bought my 2002 Camaro SS LE with the push button start already installed. its wired up so the key has to be on, then you push the button and boom. however the key switch will not start the car.
how hard would it be to switch my current push button (ignited performance, non illumnited http://cgi.ebay.com/ebaymotors/Engin...item56433e25a4 ) to a honda S2000 push button?
all i really want to do is change out the button, not the wiring or anything else. the text is starting to wear off the current button.
I know I'm late to the party here (I think you mentioned you purchased to S2000 button), but for future reference, I have the illuminated version of the ignited button and after a couple years the text wore off on mine too...I just contacted ignited http://www.ignitedperformance.com/shop/ and told them what happened and they sent me a new button lense. This time I sprayed a layer of clear-coat over the button lense (the lense actually unscrews from the button) and it's been perfect ever since.
Also if you want to restore your key functionality in the ignition:
Where the install instructions http://www.bowlingss.com/Mods/Instal...e%20Switch.mht cut the yellow wire (7th and 8th picture), you need to join it back together...I tapped into this yellow wire instead of cutting it for my install incase I ever needed to use the key.
