I Need Some Ideas...
Restricted User
I have run into a problem...I just installed my Nitrous kit and my line locks, but now I I don't know where to install the switches and buttons for them...I already have the SLP fan control switch mounted under my dash by my right knee....but I haven't the slightest idea where to put the switch for the line locks, or the switch and push button for the nitrous activation and purge....so I would greatly appreciate some ideas and recomendations...
![Stupid](https://ls1tech.com/forums/images/smilies2/stupid.gif)
Restricted User
the only thing thats sucks is that ashtray is behind my shifter and I sleeve opens it sometimes...but other than that I like that....and I'm about to run to autozone to start that little project...
one of mine is fan as well, I have arm, opener, fans, line lock master switch, and then through the magic of relays the momentary button is purge when the line lock switch it off, then when you flip the line lock switch on it becomes line lock instead of purge
This is the NX kit. The left switch has three positions. The up and down positions are the arming switch and the bottle heater. The middle position is the off position. The middle switch is the purge and the right switch is the bottle open/close switch. The setup matches our interiors perfectly. The red button is for my line lock. I put my fan switch in the ashtray.
![](http://img150.imageshack.us/img150/2216/img0425jpg0ph.jpg)
Originally Posted by Zero4488
How did you make that panel? Cause I really want one of those....cause then I can have my line locks, my purge and my NX switch right there....
