Change-out on drivers window motor
Please help!!!
Buce
http://shbox.com/page/windowmotor.html
Basically you put a big drill bit on the rivet heads and the soft aluminum goes away. Make sure you brace the window... all the details are on the web pages.
I did my passenger side door 2 years ago, I have to do my driver side now...
. Just be sure when you put the new one in you tighten the little bolts that are supplied with the new motor as tight as you can cause I had one back off and I had to pull it all back apart. Trending Topics
Thanks again,
Speedin' Sam
