hids on trans ams?
Old Sep 18, 2007 | 04:44 PM
2KnbmTA's Avatar
Default hids on trans ams?
looking into getting hids for my car. i was told that i had to get new housings cause they dont make hids that fit into the stock sealed beam housings. also, do they make projectors for t/a's, or do u have to make them?
Old Sep 18, 2007 | 05:54 PM
SCRWS6
Guest
Posts: n/a
can definitely make em, search the LIGHTING FAQ
Old Sep 18, 2007 | 05:57 PM
The Guz's Avatar
There are a few guys running HIDs on there trans am's. I am sure they will chime in. I know there are a few guys who purchsaed the sealed beam that is able to support an HID bulb. If you want to do projectors you are on your own as I have not seen any aftermarket one's. But both options are doable.
Mike
Old Sep 18, 2007 | 06:14 PM
VIP1's Avatar
Copy & Paste Moderator
Yeah, the Lighting FAQ (in the "Hall of Fame" sticky) is a good place to start.
Old Sep 19, 2007 | 11:50 PM
VIP1's Avatar
Did the Lighting FAQ help?
Do you have any questions?
Old Sep 20, 2007 | 07:31 AM
Transamin00's Avatar
2- $150 per kit on ebay for bulbs
4 - $25 new sealed beam headlights
30 min worth of work per headlight then install.
new sealed beam headlights have metal backs, cut away the white stuff and unscrew the bulb and take it out, put the new HID bulb in, and high temp silcone it up. DOT apporved, Factory looking HIDs.
Old Sep 20, 2007 | 07:53 AM
bjamick's Avatar
^^^^^^ That looks amazing.. I would definitely love to have a set of those ..
Old Sep 28, 2007 | 08:12 PM
Tram's Avatar
But are you blinding everyone coming at you with that setup?
