Project "ObseSSed"
Old Nov 24, 2007 | 08:02 AM
  #141
Martin HD-28's Avatar
Looks stupid.
Old Nov 24, 2007 | 08:08 AM
  #142
But kudos for having the ***** to do it. I don't like it all but at least you're putting hard work into a Camaro, hopefully one day the REAL Camaro bug will bite you!
Old Nov 24, 2007 | 08:12 AM
  #143
slammed1500's Avatar
and what would that be ??
pls tell
Old Nov 24, 2007 | 01:02 PM
  #144
ZetaVeinteOcho's Avatar
Originally Posted by NSTY WS6
PWN3D
As for ZetaVeinteOcho, You must have some personal issues, or have no life if you have the time to come in this thread and post negative **** as much as you do. Almost sounds like your jealous. Take off the white sheet, get off your high horse and look around. If you dont like the car, why keep coming back in this thread, take your *** to the other few thousand threads.. If I was a mod/admin, I would have sent you on a temporary vacation already! [/SIZE]
Jealous....never...and thats why you're not admin. And I'll keep my **** right here and nothing you can really do about it. Check all my other posts, while others post its the best thing since bread, I'm merely showing why it isn't. And to VW guy, I am fully aware about active handling suspension systems, my reference was to hydrolics like the LOLO's have. Not ride height adjustment systems that are not so extreme.
Old Nov 24, 2007 | 01:16 PM
  #145
JasonWW's Avatar
I don't know who VW is, but I was the one talking about active suspensions.
Hydraulics are hydraulics as far as I'm concerned. Whether it be on an airplane, tractor or car, it's the same principle. When it specifically concern cars though, lowriders have already got everything figured out. 12 volt motors, 12 volt dump valves, etc... So why not adapt that technology in a new and creative way? It's going to act as an adjustable upper shock mount for the coilovers. So you still have the great coilovers for handling, but you can do so much more.
Old Nov 24, 2007 | 01:26 PM
  #146
RA4926's Avatar
Originally Posted by slammed1500
this is on my truck i will be making one for the camaro
LOVE THE FLIP UP PLATE!!!
Old Nov 25, 2007 | 01:24 PM
  #147
some pics with the fenders off
Old Nov 25, 2007 | 10:13 PM
  #148
JasonWW's Avatar
Thanks for the pics.
It looks like your front tires are narrow enough that you didn't have to cut that outer lip that hangs down. I'm running 285 fronts and that lip will have to be removed. I guess I can figure out a way to do it. I could probably remove that whole outer triangle shaped reinforcement if I brace the tubs. Don't you think?
Old Nov 28, 2007 | 05:40 PM
  #149
Alt's Avatar
Alt
Do you think you could take the guts out of a standard 10 switch switchbox and stuff them inside the center console for a more clean route?
Old Nov 29, 2007 | 12:31 AM
  #150
02Z28LS1's Avatar
Originally Posted by clean99
you should make a license plate thing that flips out for the camaro's front and sell them
haha, hell yeah
we could roll around with the front plate hidden, then if you ever get pulled over, just flip it back out. when the officer tries to write you a ticket for no front plate, just say "what are you talking about? i have a front plate"
then they go up front to check and they're all like.....WTF?
Old Nov 29, 2007 | 12:41 AM
  #151
SRfastZ's Avatar
did you get your rear end cut ... what size wheels are the ones in the back.. big *** lip.. size ?
Old Nov 29, 2007 | 12:48 AM
  #152
cruiSSin LS1's Avatar
WTF is going on with that car!!!! i have seriously been laughing for about 5 mins straight!!!
Old Nov 29, 2007 | 01:10 AM
  #153
chromeplated500's Avatar
I like it... the shaved handles catch my eye the most... definently unique...
Old Nov 29, 2007 | 07:34 AM
  #154
yes rear end is narrowed. the wheels are only 20x10 i had 2 pull them in a lil 2 get them away from the 1/4panels
? its bagged
Old Dec 8, 2007 | 12:21 AM
  #155
JasonWW's Avatar
Hey Kenny, I remember you said you were going to switch the front bags to a different setup, did you see my thread on these strut bags?
https://ls1tech.com/forums/suspension-brakes/803631-air-ride-using-your-front-shocks-350-a.html
Nevermind, I remember telling you already.
Does a bag with a 1/4 NPT fitting mean the hole is 1/4" in diameter?
This is the bag:
https://www.universalairsuspension.c...f9225591d1eed8
Is that size port going to limit how fast the bag can be filled?
Is it better to mount the valves inside the car so they stay clean or on the outside so you can't hear them?
Old Dec 14, 2007 | 08:42 AM
  #156
https://ls1tech.com/forums/showthread.php?t=803631
This is the bag:
the 1/4 will limit it a lil but if you dont care about hopping it then i wouldnt worry about it
the shock waves on my dads 57 have 1/4" holes in them and the speed is good 4 that car
it has the airride big red valves
the vavles are in the car on my wifes camaro i just ran a dump line out side so u can hear it
but mounting the outside would be fine also
Old Dec 15, 2007 | 12:46 PM
  #157
JasonWW's Avatar
Originally Posted by onyxxtreme
there was a Black LT1 body TA on here a few years ago, that had a narrowed rear and was mini-tubbed. It had a 2" or maybe slightly lower drop, and some 17's, looked completely awesome. Probably the best lookin Fbody ever on this site
I was just re-reading this thread. I think this is the car your talking about.
Old Dec 15, 2007 | 12:50 PM
  #158
bene's Avatar
Trunion King
Anymore updated pictures?
Old Dec 15, 2007 | 01:18 PM
  #159
JasonWW's Avatar
I just noticed something else. You don't have the brake system installed. Will the master cylinder clear the tall humps you added?
Old Dec 15, 2007 | 02:22 PM
  #160
JasonWW's Avatar
