Project "ObseSSed"
Old Dec 15, 2007 | 04:52 PM
  #161
texasreb18's Avatar
badass work man..so what if it may hurt performance/handling? it will still be faster than most cars, and most importantly, he will have FUN in it. i guarantee you he will get more looks than pretty much anyone on this board
oh and btw here's a bagged corvette:
Old Dec 15, 2007 | 06:29 PM
  #162
Ls1CamaroGuy87's Avatar
Doing that to a Corvette is just plain ridiculous
Old Dec 15, 2007 | 06:30 PM
  #163
JasonWW's Avatar
Nah, it's better now. You can raise it a lot for steep driveways instead of scrapping. The rims are kind of funny looking, though.
Old Dec 15, 2007 | 06:36 PM
  #164
^^hmmm I never though about it that way. and yeah the rims are hideous
Old Dec 15, 2007 | 06:58 PM
  #165
JasonWW's Avatar
I just reworked a photo of my car.
Here's a C4 on air.
Old Dec 15, 2007 | 07:03 PM
  #166
JasonWW's Avatar
Yellow Lambo on air.
http://www.universalairsuspension.co...sid=117&cid=17
And to show some performance from an air setup, here is a vid of a drift car using it. It's a bit long. You don't have to watch the whole thing.
http://www.universalairsuspension.co...DRIFTONAIR.wmv
Really cool video showing the before and after performance of a Magnum. It shows how much the handling improved.
http://www.youtube.com/watch?v=Fn8XKR4Q9CU
Maybe this will open some people eyes.
Old Dec 15, 2007 | 07:33 PM
  #167
bangdiggity's Avatar
i think your car was the first bagged 4th gen i ever saw cause i remember i used to have a pic saved on my computer when you were draggin it, i thought it was badass. the shaving definitely looks smooth and i love those wheels, that lip is awesome. here is one of my buddies trucks he bagged and i think the intros are pretty similar to yours, just thought id show you. cool car and good luck finishing it man.
Old Dec 15, 2007 | 08:36 PM
  #168
slammed1500's Avatar
Originally Posted by JasonWW
I just noticed something else. You don't have the brake system installed. Will the master cylinder clear the tall humps you added?
the master cylinder does clear
thats one of the reasons i did it that way
sorry no new pics the car is all apart again so i can finish all the welding and grinding and the i will prime the engine bay
and then ill start putting the motor in and try 2 get every thing running
after that ill pull it all apart again and paint the engine bay that way ill have no surprises after the paint work
Old Dec 15, 2007 | 08:41 PM
  #169
cool post it might change a few opinions but then again maybe not lol
o your car is going 2 look sweet slammed jasonww
clean truck bangdiggity
they are the same wheels intro vrods
Old Dec 19, 2007 | 10:39 PM
  #170
JasonWW's Avatar
You know, I think I may just swap the IRS in the back of my car now. That way I'll need to do less sheetmetal work. I won't need to clearance the pumpkin or the torque arm. I mean, why do all that work now when you don't really need to? Doesn't that make sense?
BTW, there a few other guys looking onto air setups, what were you saying about a good choice for the rear bag? The 2600 rode smoother? Is that a Contitech and would it be the 2 ply or the 4 ply?
I think for my own setup I'll run 2 1/2" fill valves for the front and the other 6 will be 3/8. Then I'll get adjustable slowdown devices if I need to.
For those guys who don't have a lot of space what would be a minimum tank size to go from all the way down to all the way up using a 200psi compressor? Would a little 2 gallon tank tucked away do that? I plan to run a big tank or 2 smaller tanks and show them off, so I'll have plenty of extra air for myself. It's just that some poeple want to keep the t-top area clear so a smaller tank would be better for them.
Old Dec 20, 2007 | 07:57 AM
  #171
this was the old set up in my wifes car
it was a 5 gal tank with 2 compressors and worked really good had plenty of air 4 the car at 160 psi but that was with the v6
now my truck has a 6 gal. at 180 psi and it needs all of it 2 raise all the way 2 ride hight only around 1 1/2 to 2 times maybe
so a 2 gal i dont think will be enough maybe at 200 psi but im not sure
if anything u will only be able 2 raise the car 1 time
but it all depends on how high you have 2 raise it and the wight of the car
putting the irs is still going 2 be alot of work with making all the mounting and susp. parts work
i have 2500 universal air double below bags in the rear and they ride alot better than the 2500 firestone bags did
Old Dec 20, 2007 | 09:35 PM
  #172
JasonWW's Avatar
With the IRS I don't have to make any mounting points for the A-arms. That's the beauty of it. It's pratically bolt in. It's very similar to the Cobra IRS. Ford designed it to bolt into the place of the solid axle. All I have to do is make 4 mounts to bolt in the cradle. The more I think about it, the more I realize it needs to be moved to the front of my list. Once that part is done then I can focus on a new gas tank, tubbing the rear, dual exhaust, etc... I was planning on doing it much later, but it makes more sense to do it first.
So the rear bags are the "Double Play" from Universal Air. https://www.universalairsuspension.c...000b1b315bc2d9
I'll pass that along to the other guys. Why do you think the Firestone 2500 rode worse? Maybe it was a thicker rubber material? I can't really think of a good reason.
Old Dec 21, 2007 | 07:37 AM
  #173
and one other thing i just thought about is the placement of the bag on the IRS
that might be a problem
yep thats the bags that are in the rear
they also have more stroke over the firestones
Old Dec 21, 2007 | 07:45 AM
  #174
JasonWW's Avatar
Bag placement on the IRS is really different. It's more like the A-arm setup on the front of your truck, but with less weight on it. I hope the bags can work on both, but it's no big deal if I need to get different bags.
In fact, one model of the car actually came with air bags. It would probably cost a small fortune to get some factory bags, though. I think these aftermarket bags would work just fine.
Old Dec 21, 2007 | 07:56 AM
  #175
JasonWW's Avatar
Here's a pic of the IRS. I think those Double Play bags would work on both rear ends. We'll see.
Old Dec 21, 2007 | 06:08 PM
  #176
yes the will work thats the point of the double bellow bags
Old Dec 21, 2007 | 07:58 PM
  #177
KW4life06's Avatar
hes definitely into dragging. just not in 1320ft. just body parts
Old Dec 22, 2007 | 06:33 PM
  #178
sporty_drew's Avatar
Does anyone have this picture? I'd love to see it.
Old Dec 22, 2007 | 09:21 PM
  #179
Old Dec 22, 2007 | 09:26 PM
  #180
LS1BLKSS's Avatar
Banned Village Idiot
^^^thats a bad *** picture!!!
