JasonWW's More Unique Mods
https://ls1tech.com/forums/suspension-brakes/249607-bumpstop-spring-rates-inside.html
Its not as simple as it seems. You have to do a lot of measuring to make sure you don't damage the shock, but it works very well.
,very clean.I would sticky the wiring diagram for the cutouts, easy to do and works perfectly
Not into the fake tailpipes....dumps speak for themselves. The amps + heat behind the seat also comes to mind.Overall.....nice
The brake cover is very simple. I hand cut a piece of plexiglass I had laying around. I cut it to a rough oversized shape, then used a grinding wheel to trim it down further. Then I used a file to get the edges straight. Finally I beveled the edges so it would sit nice and flat with a tight gap all around. Once it fit right, I painted it and used RTV silicone to hold it in place. Works like a charm and very cheap to do.
On the headlights, all you have to do is add the light sensor from a Camaro to the dash hole and connect it to the existing wiring. Canadian Firebirds/ TA's have this done at the factory. Units shipped to the US have the light sensor deleted.
I have full control over the lights. A tiny toggle switch can bypass the light sensor if I want. I also threw in another toggle to turn off the DRL's.
I never had any heating problems with the amps, either. A lot of that depends on the amp model and the load on it.
