Real flames on the cowl...
Old Feb 7, 2008 | 01:29 PM
ZONES89RS's Avatar
In-Zane Moderator
Default Real flames on the cowl...
Not a pro job, just wanted to see what it would look like. I dont even have a real pain job so...
i just did it, i cut out the shadow i wanted, wasnt pickey i just cut it out. From there, i simply used a BS 96 cent can of paint, so for half assing it i would hate to see what i can do with real equipment, all i have is a gravity feed matco paint gun i used for the body for now.
LMK what you guys think?
The pattern...
Old Feb 7, 2008 | 01:34 PM
Whistler's Avatar
Sawzall and Welder Mod
Just playing. Keep practicing. You'll do much better with an airbrush that you can actually vary the fluid and pressure with.
Old Feb 7, 2008 | 01:50 PM
ZONES89RS's Avatar
In-Zane Moderator
Oh yea, but for a half assed 20 minuter job(including taping off the cowl) I can only imagine how it will look with a real air brush.
Old Feb 7, 2008 | 01:58 PM
Whistler's Avatar
No doubt. Here's a tip. Don't use the negative of the stencil. Use the part you cut out instead, and spray off the side of it. That will help your fire from looking so patterned.
Old Feb 7, 2008 | 03:13 PM
Ls1CamaroGuy87's Avatar
Definitely need some practice, prolly better than I could do though....I am no good at flames...only stripes...
Old Feb 7, 2008 | 03:53 PM
3pnt4maro's Avatar
definitely not bad at all....looks good for a quickie...a lil patterned but for 20 min you cant complain
Old Feb 7, 2008 | 04:42 PM
ZONES89RS's Avatar
In-Zane Moderator
Yea, net tim ill use a 3 sided pattern and a air brush....not rattle can
Whistler, ill try that in the garage soon and see how well it works, thanks for the tip.
Old Feb 7, 2008 | 04:46 PM
WsFirebird6's Avatar
yeah has potential but just looks to patterned
Old Feb 7, 2008 | 05:56 PM
ZONES89RS's Avatar
In-Zane Moderator
Yea, next go around will have more than 20 minutes involved
Old Feb 7, 2008 | 09:24 PM
TUMBLRws6's Avatar
better then my first try lol
real fire is very random...good first try like already said potential is there
Old Feb 7, 2008 | 09:26 PM
SparkyJJO's Avatar
better than I could do! Keep practicing, looks like you're at least on the right track
Old Feb 7, 2008 | 11:54 PM
ZONES89RS's Avatar
In-Zane Moderator
Yea, i think i have the fading down, that is for sure, ****, i think just a air brush would have made a 5 fold difference.
Old Feb 8, 2008 | 12:02 AM
J&J Motorsports FL's Avatar
Looks gook. Are you gonna use a translucent color over it?
Old Feb 8, 2008 | 10:43 AM
ZONES89RS's Avatar
In-Zane Moderator
No, it is just experimental, when i re primer the car it will be more serious and have more depth and not look so identical, ill be using a air brush too.
Old Feb 8, 2008 | 10:53 AM
xBROKEx's Avatar
the first thing i thought when i looked at it was ghost sperm lol. i cant say much though i have no artistic talent at all
Old Feb 8, 2008 | 12:32 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
If you are serious about wanting to do this the correct way, do yourself a favor and get a good airbrush and get Mike Lavalle's DVD on how to do true fire from www.killerpaint.com. Then invest about $20 in some templates and you'll need a couple hundred in paint and then practice practice practice! Its not a cheap thing to do- it will probably cost you at least 500 to get all the right tools and equipment, but its worth it once you get decent- then you can do a couple side jobs with the paint you already have and make some money back. This is if you have some talent and an artistic mind and some skill. Good luck.
Old Feb 8, 2008 | 02:49 PM
ZONES89RS's Avatar
In-Zane Moderator
Thanks chevy, i will see what is a good brand air brush and see what Ebay has to offer and fgo from there. I can practice with old paint anyone has laying around as long as i have reducer and hardener to go with it. I still am having to paint my wifes 86 TA and see what happens from there.
