Polishing Steel...anyone have any tips?
I may attempt to polish my red strut tower bar that doesn't match a damn thing on the car. I am going to have it stripped and then I am going to polish it.
Any pointers on how I should go about this or what I should use to do it?
Thanks.
Thanks.
Just shooting ideas around. I may end up just going to someone diff and getting it all powdercoated plain black.
BTW, there is a polished version of the bar available so I would assume its the same metal? Or am I horribly wrong? lol
-brian
Good info is good info. The guy that was goin to powdercoat the parts cannot do a piece as long as the bar so I just figured it could be polished. Could I simply polish it up and then grab a can of clear and spray it on?
-brian
-brian
-brian
-brian
i had mine polished nice and forgot and left it out in the rain and it rusted alot. i gotta re sand and polish it now.
how do you guys strip it? i used sandpaper. could i have gotten it sand blasted?
Yes, the powder coated ones are steel. A good way to tell if it's steel or aluminum is try to stick a magnet to it, if it sticks it's steel, if not it's aluminum. You can also look at the welds and/or the actual weight of the item. The aluminum stb costs considerably more than the steel. Aluminum will also oxidize over time w/o a protective coating.
