Project Flyenlow: Before and After
#44
That is the stuff that I absolutly LOVE. Nice looking car, perfect choices on appearnace mods and what appears to be top notch mechanics work. Good job would be an under statement.
#46
yup, I've always thought your car looked good. What makes it look so much different than others...is it just the wheels and stance? I've never been able to pin-point what makes it look better than most.
#48
Good looking car, if this another one that the Zeus gang will be bringing to Atlanta and make mine look bad again this year??
Very nice swap, and alot of hard work there!!
#50
It is a great show, and I am looking forward to hanging out with the Zeus group if this will come thru for us. Mine's just a dang driver tho, not a show piece like the one's you all be bringing.
#53
Specs are:
-355ci LT1
(aftermarket crank, SCAT rods & SpeedPro pistons)
-stock LT1 heads
(cleaned, decked to 11.1 CR, 3 angle valve job w/ all new valves & 918 springs)
-CC503 cam
-double roller timing chain
-CSR electric water pump
-Scorpion 1.6 RR
-emissions delete
-AC delete
-fully hand ported LT1 intake manifold
-Holley 58mm throttle body
-Jet Hot Long tubes
Full specs are in this thread as well as more pictures:
https://ls1tech.com/forums/conversions-swaps/879242-project-flyenlow-3-4-v6-t5-lt1-t56-swap.html
#55
Nice set of mods ![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
I ran the cc503 on stock heads a few years back, it had some great street manners and a real nice power band all the way up to 6000rpm, you will definately like it.
