Project Flyenlow: 3.4 V6/T5 to LT1/T56 swap
When I bought my 1995 Firebird on October 1st, 2003 it had a 3.4 Liter V6 M5. Since buying it I've always had the desire to go faster/handle better. I started from the ground up pretty much. A catback(Flowmaster) and wheels(chrome Firehawks) were first. Then, I bought a friend’s (WS6FirebirdTA00) old suspension setup back in Nov 2005 (springs/shocks). This past summer I bought and installed a UMI adjustable TA and PHB, along with LCAs and relo brackets.
Now comes the best part, motor swap time. Before I decided to do the swap, I wanted to sell my car and buy a newer WS.6 or something of the sort. After becoming good friends with the guys at Zeus Performance(Charlotte, NC) I decided otherwise. I wanted to keep my car and do a swap. And so it began:
This process began in June 2007 when I initially bought a wrecked 97’ Anniversary Z28...my car has now been off the road for almost 3 months...it's come a LONG way...
Engine:
-355ci LT1
(aftermarket crank, SCAT rods & SpeedPro pistons)
-stock LT1 heads
(cleaned, decked to 11.2 CR, 3 angle valve job w/ all new valves & 918 springs)
-Impala head gaskets to bump CR to 11.5:1
-CC503 cam
-double roller timing chain
-CSR electric water pump
-Scorpion 1.6 RR
-emissions delete
-AC delete
-charcoal canister/line delete
-fully hand ported LT1 intake manifold
-Holley 58mm throttle body
-160* thermostat
-Tuned by Alvin @ PCM4Less
-MSD Billet Opti
-Moroso wires
-Custom Power Steering setup
Exhaust:
-Jet Hot Long tubes
-Hooker ORY
-GMMG Chambered stainless steel catback
Fuel:
-stock injectors (soon to be 30lbs)
-Walbro 255 pump
Drivetrain/Brakes:
-D&D Stage 2 T56
-stock clutch
-billet steel Flywheel
-Pro 5.0
-aluminum driveshaft
-4.10s back to 3.42s (4.10s coming again)
-LS1 brakes
-ABS delete
other:
-Gauges: mechanical:oil/fuel pressure - electric:water temp
-TA high rise hatch
-Edelbrock Coilovers/IAS shocks
Future Plans:
-LPP Stainless Steel Headers
-Custom Y-Pipe to gain clearance
-C5 brake upgrade
-UMI TA relocation brace
Here are the pictures of the swap:
Before the teardown
![](http://i8.photobucket.com/albums/a49/tbird31/online1-2.jpg)
New hatch
![](http://i8.photobucket.com/albums/a49/tbird31/Dscn97892.jpg)
New seats![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://i8.photobucket.com/albums/a49/tbird31/01-02-08_1755.jpg)
interior
![](http://i8.photobucket.com/albums/a49/tbird31/DSCN0050-1.jpg)
Motor
![](http://i8.photobucket.com/albums/a49/tbird31/DSCN9601.jpg)
![](http://i8.photobucket.com/albums/a49/tbird31/n36606973_33573843_672.jpg)
![](http://i8.photobucket.com/albums/a49/tbird31/DSCN9852.jpg)
![](http://i8.photobucket.com/albums/a49/tbird31/DSCN9857.jpg)
![](http://i8.photobucket.com/albums/a49/tbird31/DSCN9891.jpg)
Tearing apart the car
![](http://i8.photobucket.com/albums/a49/tbird31/DSCN9905.jpg)
![](http://i8.photobucket.com/albums/a49/tbird31/DSCN9911.jpg)
Ceramic coated intake
![](http://i8.photobucket.com/albums/a49/tbird31/DSCN9940.jpg)
MMM
![](http://i8.photobucket.com/albums/a49/tbird31/DSCN9945.jpg)
![](http://i8.photobucket.com/albums/a49/tbird31/DSCN9950.jpg)
![](http://i8.photobucket.com/albums/a49/tbird31/DSCN9958.jpg)
Peace out V6
![](http://i8.photobucket.com/albums/a49/tbird31/DSCN0001.jpg)
Vroom vroom
![](http://i8.photobucket.com/albums/a49/tbird31/DSCN0004.jpg)
Nasty ****...
![](http://i8.photobucket.com/albums/a49/tbird31/DSCN0016.jpg)
primed
Engine:
-355ci LT1
-stock LT1 heads
-CC503 cam
-Scorpion 1.6 RR
-emissions delete
-AC delete
-160* thermostat
-MSD Billet Opti
-Moroso wires
Exhaust:
-Jet Hot Long tubes
-Hooker ORY
Fuel:
-Walbro 255 pump
Drivetrain/Brakes:
-D&D Stage 2 T56
-stock clutch
-Pro 5.0
-LS1 brakes
-ABS delete
other:
-TA high rise hatch
Future Plans:
-C5 brake upgrade
Before the teardown
New hatch
New seats
interior
Motor
MMM
Peace out V6
Vroom vroom
Nasty ****...
primed
![](http://i8.photobucket.com/albums/a49/tbird31/DSCN0040.jpg)
LS1 brakes
![](https://i8.photobucket.com/albums/a49/tbird31/DSCN0120.jpg)
![](https://i8.photobucket.com/albums/a49/tbird31/DSCN0121.jpg)
something tells me i'm going to have ground clearance problems :roll:
![](https://i8.photobucket.com/albums/a49/tbird31/Dscn01232.jpg)
coming together
![](https://i8.photobucket.com/albums/a49/tbird31/DSCN0164.jpg)
looking somewhat decent again
![](https://i8.photobucket.com/albums/a49/tbird31/DSCN0162.jpg)
Here are some pictures of the exhaust finished up.
![](https://i8.photobucket.com/albums/a49/tbird31/DSCN0182.jpg)
![](https://i8.photobucket.com/albums/a49/tbird31/DSCN0183.jpg)
![](https://i8.photobucket.com/albums/a49/tbird31/DSCN0181.jpg)
Aparently I made the Y-pipe tuck up pretty well.
![](https://i8.photobucket.com/albums/a49/tbird31/DSCN0190.jpg)
Latest picture, the rest of the work can pretty much be done on the ground:
coming together
![](https://i8.photobucket.com/albums/a49/tbird31/DSCN0185.jpg)
I dont usually curse on the boards... but HOLY ****... That is one of the best looking 93-96 birds Ive seen. Not even sure which part of it makes it so nice to me...but I love it!!!
Not only is the car clean and very tasteful, but your work seems to be top notch. I really want to do my under carrige like that for my build this spring. Thats so nice to have it all cleaned and painted and looking good...even in the places people wont see.
Definitely keep us posted with the progress that you have left, and get some vids and what not of it finished!!
J.
J.
I finished up wiring the radiator fans yesterday. I am still using the V6 engine bay harness so it was wired for 1 fan instead of 2. I just spliced off of the exsisting wires and added a new plug.
Question I had though is that I don't know if it will decrease the power that is fed to the fans since it will be split. Just hoping it won't affect them in a negative way and make the car not cool off fast enough. I figured it should be ok.
Brakes and computer tomorrow. Car should be on the road by the end of the week. Fingers crossed.
By spraying the underbody of the car and the engine bay black, was one of the best idea/choice to make. It really adds alot. I like all the work I see. Those wheels look perfect on a white T/A. and the stance looks so nice. But you may have clearence issues with your long tube headers. Just a lil something that you might want to look into, is SLP has and or is still in the process of making new long tube headers that help alot alot with ground cleanerence issues.
P.S. I am going to keep looking back at your car for reference because eventually my 1992 Firebird is going to go through this process.
