Detail: '07 BMW 328i & '08 Cadillac CTS
Here are some of the results I've been getting using Menzerna SIP and Tropi-Care TC-3 xP
'07 BMW 328i
'08 Cadillac CTS
'07 BMW 328i
'08 Cadillac CTS
damm, any car you detail looks amazing. what pad and speed setting on the PC do you use with the sip polish and what pad and speed do you use when applying you sealant or liquid wax with the PC thanks.
To answer some remaining questions...
SIP is much more abrasive than IP. IP is meant as a finishing polish for hard clear coats (GM, BMW, MB, etc.) and a go-to polish for softer clear coats (Honda/Acura, Porsche, etc.)
Typically one uses an Orange (or yellow/foamed wool in severe cases) cutting pad with SIP to get its full correcting ability. IP is mostly used with a white light polishing pad. However, it all depends on the job. You can use orange/IP, white/SIP, it all depends on what you're working with and your level of experience in using them.
Typically, you'll want to use higher speeds for polishing (5 or 6 on a PC) and lower speeds (2-3) with no-cut pads for applying the final sealant/wax.
I sent you a PM. thanks.
Thanks for all of the compliments guys! I'm sorry I haven't been quicker to reply to your comments and questions! I have been away from a computer since last Thursday! But I'm back in town now!
damn that cadillac makes that beemer look like a camry. I hate the look of the style bmw's, horrible back lights, weak flowing lines but a nice grill. the CTS is just gorgeous, I can just sit and stare at the cow catcher style front grill for hours.
