Pics of my custom coil bracket on stab bar
Heres some pics of a custom coil bracket that i came up with and made while i was installing my Nasty Performance coil relocation kit.What i did was use bigger spacers that slid over top of the smaller spacers that came with the kit. This was done because the bigger spacers looked better and also cured the sagging issue when doing this with the smaller spacers alone..
I used a coupler type fitting (long nut) that i rounded on its one side(half of coupler) and tapped the rounded end into the end of the bigger spacer on each end. By doing it this way, im actually able to assemble all of these coils together and tighten everthing before its attached to the stablizer bar. This also illiminates the need to pull both piece of allthread completly out to change out 1 coil,and have spacers and washers falling all over the place(intake) LOL!!The whole coil assembly is fitted inbetween the 2 custom supports that i made & welded onto the stabilizer bar and is attached useing 4 bolts.
After everthing was fited up and welded on ,i disassembled and had everthing powder coated bright red and this is what she looks like!Estamate time 1 weekend LOL!!and one pissed off wife if married![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
http://s243.photobucket.com/albums/f...oil%20bracket/
