This buffer OK for removing swirls/minor scratches?
http://www.harborfreight.com/cpi/cta...emnumber=92623
I've been doing some researching in previous threads and I've noticed most people buff from around 1000-1500rpm. This buffer goes to 3000rpm. As long as I use the right pads,compounds,polishes, whatever... will I be able to remove swirls? I know everyone would recommend PC and such but I'm only 18 and money is tight right now.
Also, FYI, under the "sponsor sales" section, tropicare has a 10% off coupon good until end of July.
To the OP, you're not going to be able to get a $40 buffer that will have enough power to remove swirl marks. It sucks, I know. I'm planning on getting the Porter Cable myself so I can get rid of the holograms left by an incompetant detailer.
Also, you may want to just stick with a cheap "cover up" solution rather than trying to buff the swirls out with poor equipment--at least until you have enough money to get the PC. Klass All-In-One seems to be the favourite cleaner/sealant for hiding minor swirls and leaving a shiny finish. Also, I use Meguiars #21 syn. sealant on my car. While other liquid polishes still showed the holograms on my car, the #21 hid them. So, assuming you're not dealing with deep scratches (the kind that turn white b/c they fill up with dry wax), you can probably get by with investing $20 into a high quality sealant.
LS1TECH Sponsor
Porter Cable and other random orbit buffers have their speeds measured in orbits/minute. (OPM) Their rotation is much safer as the machine action vibrates up and down at the same time it spins in an elliptical orbit to dissipate heat from building up on the surface.
dont get a high speed buffer unless u know what u are doing becuse u can do damage if not
this is all u should ever need ===> http://www.tropi-care.com/product_p/tcpc-30.htm
To the original poster, I would seriously reconsider using a rotary if you've never used one before. Its a powerful machine, way more than a PC, and can do some serious damage in a short amount of time. I would practice on a scrap panel for a bit before even attempting using it on your car if I was you.
By the way its a hit or miss with the Harbor Freight rotary. I've read instances where some people have used it for a while without any problems. Others weren't so lucky. Mine gave out after only using it about four times, but oh well I'm only out $20 and I got some pretty good practice out of it. I'm getting a Makita rotary next.
Location: The Republic of Texas, just south of the United States...
I would seriously reconsider anything from Harbor Freight; buying a power tool from them is like getting a flue shot from a heroin addict, in the end you're fucked.
The porter cable model 7336 is THE piece to own in auto detailing. You'll spend maybe 120-150 bucks but you'll only spend it once and be happy that you did. I've had mine for 5 years now and never had a problem.
Operating a rotary buffer at any speed can **** up your paint BAD if you haven't experience with it. They work great and are a wonderful tool but are dangerous to paint in the hands of the unskilled.
