How to remove the Trans Am emblems on side of door????
Old Nov 25, 2001 | 03:02 PM
1badls1bird's Avatar
Default How to remove the Trans Am emblems on side of door????
How do you remove them. I heard floss, but I want a btter way?? Any ideas. Use a har dryer? What do I use to pull it off or do I do it by hand? Thanks!
Old Nov 25, 2001 | 03:12 PM
BIGBOS's Avatar
Default Re: How to remove the Trans Am emblems on side of door????
Hair dryer
Old Nov 26, 2001 | 01:54 PM
11 Bravo's Avatar
I sprayed around the emblems with wd-40 to soften the adhesive, let it soak a couple of minutes, then slid fishing line behind the emblems and it came off easily. WD-40 also makes it easy to remove what's left on the door before you put the new emblems on.
Old Nov 26, 2001 | 06:31 PM
Cool, thanks! I will try that! Will floss work just as well?
Old Nov 30, 2001 | 11:54 PM
hankd's Avatar
Are you putting a different color back on? Or going with the sleek look?
Old Dec 1, 2001 | 02:01 AM
I am putting balc ones on. Right now I have Firebat stickers on the stock emblems, but I think just new black emblems will look better! I want everyone to know I drive a Trans Am, hehe! There is not way I can be a sleeper when my car is ungodly loud, hehe! <img src="graemlins/gr_images/icons/mad.gif" border="0" alt="[very mad]" />
Old Dec 7, 2001 | 11:35 AM
Jeremy's Avatar
[quote]Originally posted by 1badls1bird:
<strong>How do you remove them. I heard floss, but I want a btter way?? Any ideas. Use a har dryer? What do I use to pull it off or do I do it by hand? Thanks!</strong><hr></blockquote>
First thing to do is get it heated up with the hair dryer, at the same time slide fishing line behind the emblem(gets more of the gunk off and doesn't brake like the dental floss) Then I used Goo Gone to get the gunk off. Let it sit for a couple of minutes then peel it off. I did this on my Z28 emblems because I have the 69 Z/28 emblems coming in.
Later,
Jeremy
Old Dec 8, 2001 | 07:08 AM
V6 Bird's Avatar
Plastic puddy knife with the emblems presoaked in GOo GOne. Works the best. <img src="images/icons/smile.gif" border="0">
