Which drag wheels to get?????
[ December 10, 2001: Message edited by: TransAm2002 ]</p>
XP series rims are heavier than stock wheels. Strictly for looks. Why do you want 16" rims on the back? The draglites in 15" and 16" require the same amount of caliper grinding. 15" wheels are cheaper, lighter, and have a TON more tire choices than 16" wheels.
Tony
<strong>I like my 15X3.5 and 15X8 pro-stars =)
[ December 10, 2001: Message edited by: Mike Hoffpauir ]</strong><hr></blockquote>
Any grinding to get them to fit?
Prostars also come in 16's. I would not at all consider the XP series. Go with the 96 series Prostars or the Drag Lights.
My draglites need alot of grinding on the rear and spacers front and back. Even with the grinding in the rear calipers i needed spacers because on long drives with them the calipers would swell up and rub the wheels on the inside. I could prolly grind them more but i don't want to shave them down anymore than they are.
<strong>I like my 15x3.5 front and 15x8 rear Weld dralites but if i had to do over again i would get the 15x4 front </strong><hr></blockquote>
what would the half inch difference make? not flaming, actually asking <img src="gr_stretch.gif" border="0">
Chris
Another question I had, whats the bolt circle that all the rim pages always list... is it 5x4.75 for our cars?
as for backspacing, for a 15x8 rim, you would need a 5.5" backspacing. don't know of centerline has a 6" BS though for a 15x8.5" rim.
Chris
but since im a helpful guy i took a look in the wheels/tire section, and this is the sticky there, im sure it has what you need.
https://ls1tech.com/forums/wheels-ti...must-read.html
