rk sport carbon fiber grille
where did you guys get the ones with the flat front? All the ones I have seen have the words RKSport engraved in the front, which looks like ****.
I might pick one up if I can get one without the RKSport logo on it.
Old thread...but need help.
I just had my RK Sport grille painted black. What's the best way to install it?
I'm thinking 4 small holes on the outer and inner edges of each side with the gloss black plastic push pin/christmas tree style/ retainers is best.
I didn't use double sided tape, I went ahead and used the clips it came with. After I got it back from paint, I marked where I wanted the holes on the insert, then trial fitted the insert to the bumper and marked on the bumper where I wanted the holes (through the holes on the insert) and then I removed the insert and drilled the holes. I then installed the wire mesh on the grill insert, put it in place, and installed the clips. I only used one clip on each side.
I'm attaching a pic of where my clip is installed. I installed my grill SEVERAL years ago, and yes, there are a lot of rock chips, but this is a close-up shot with flash, so it's no where near as bad as it looks close-up
