Just installed Harlan shiftlight!
Old Dec 13, 2001 | 12:53 AM
ExtremeZ28's Avatar
Default Just installed Harlan shiftlight!
Woo with the help of my friend Casey(Azzhauler) we just installed my new red harlan shiftlight woo <img src="gr_grin.gif" border="0"> a mental note to everyone....if you have that wierd alarm type thing that kind of looks like a port to hook up autotap too DONT take it off your car cause we took it off not thinking we needed it on there and the car wouldnt start so we put it all back on and bam started right up....Anyway i cant wait to try it out tomorrow with it set at 6k hehehe <img src="gr_grin.gif" border="0"> <img src="gr_grin.gif" border="0"> Thanks Harlan for a great product now i dont have to stair at the tach anymore!! <img src="gr_stretch.gif" border="0">
Old Dec 13, 2001 | 08:51 AM
bigSS's Avatar
Default Re: Just installed Harlan shiftlight!
Becarefull, the red is damned bright at night! I almost blinded myself the first time! <img src="gr_grin.gif" border="0">
Old Dec 13, 2001 | 10:13 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Actually the red is the best color for not blinding you at night. Why do you think they use it for doing night maneuvers in the military and on traffic lights. You can see it very well, but it doesn't blind you to where it hampers your night vision.
Is anyone else still having a problem with it coming on occasionally when their wipers are on? I had the second version which was supposed to have addressed this, but every once and a while it comes on when I'm cruising at about 1800 rpm and the wipers are on delay.
Who knows....
B
Old Dec 13, 2001 | 02:07 PM
DV8's Avatar
DV8
[quote]Originally posted by Pewter_00_TA:
<strong>Actually the red is the best color for not blinding you at night. Why do you think they use it for doing night maneuvers in the military and on traffic lights. You can see it very well, but it doesn't blind you to where it hampers your night vision.
Who knows....
B</strong><hr></blockquote>
You're right on red being the best color for night racing, much better than the yellow or green.
I've had the light go off with the wipers, but only on the mist setting. Kinda weird, but it doesn't bother me. I also have the second version.
<img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" />
Old Dec 13, 2001 | 02:17 PM
y2khawk's Avatar
uggg
which second version?? <img src="gr_images/icons/wink.gif" border="0">
It's on version 3.0, version 3.1 goes out end of the week.
It's only and f-body problem too <img src="images/icons/rolleyes.gif" border="0">
hmmmm
Old Dec 13, 2001 | 02:29 PM
CRASH 02's Avatar
My light does the same thing. When I turn on my wipers, when I roll down both windows at the same time with the lights on at idle, when my air pump kicks on at idle also. Is there a good place to put the red wire? Mine is currently in the accsy port in the fuse panel.
Also I have some good picks of the install that a friend and I did on my 02 T/A. We put it in the middle set of vents in to one closest to the driver. We used the placstic clip that holds the throttle cables to the A/C line on a car with TCS. We put a small piece of thread all and 2 nuts on it so you can adjust the height and angle of the light. Everyone that has seen the install now wants me to do theirs just the same. I might just have to email them to someone that can post them on an install site.
Jason
Old Dec 13, 2001 | 02:36 PM
Gary's Avatar
Actually, when it rains the light flashes for no reason once in a while. I guess when it rains I have my wipers on.... so yeah.... it has happened to me too.
What could be the reason for this. I have check the connections to the pcm rpm wire, and it is water tight. Very confusing.
Old Dec 13, 2001 | 03:06 PM
Nine Ball's Avatar
LS1Tech Co-Founder
moving to body/interior section of site <img src="gr_images/icons/wink.gif" border="0">
Old Dec 13, 2001 | 03:21 PM
y2khawk's Avatar
It's electrical system noise.
putting a capacitor on the power and ground lines will help the problem. I made some changes in the reset portion of the code to check for the source of reset, make sure it was power-on, not low voltage.
There's enough spike in the power system to cause the light to trip the low-voltage reset. Like when the wipers move, big draw from the power windows, etc.
Who's got on that does it?? more than so far?
Old Dec 13, 2001 | 03:54 PM
FreakZ's Avatar
So all orders are going out Friday?
Old Dec 13, 2001 | 04:03 PM
wizkid's Avatar
Install Director
You guys use wipers???????????????????????????????????????????? ????????????????? <img src="gr_eek2.gif" border="0">
That is the big question here!! <img src="gr_images/icons/wink.gif" border="0">
Eric
Old Dec 13, 2001 | 04:35 PM
y2khawk's Avatar
[quote]Originally posted by wizkid:
<strong>You guys use wipers???????????????????????????????????????????? ????????????????? <img src="gr_eek2.gif" border="0">
Eric</strong><hr></blockquote>
That's why i never found it initially <img src="images/icons/rolleyes.gif" border="0"> <img src="gr_images/icons/wink.gif" border="0">
Old Dec 13, 2001 | 04:36 PM
y2khawk's Avatar
[quote]Originally posted by Silver99LS1:
<strong>So all orders are going out Friday?</strong><hr></blockquote>
i should be able to get them out saturday morning, and monday <img src="gr_stretch.gif" border="0">
friday is late work night for the GF, that means assembly time
Old Dec 13, 2001 | 04:41 PM
CRASH 02's Avatar
I am glad to see that they are going out. I ordered my 2nd one just over a week ago.
Old Dec 13, 2001 | 08:21 PM
ExtremeZ28's Avatar
hmmmm i cant seem to get it to flash at the right RPM....i just tried setting it at 1500 just so i didnt have to rev it so high <img src="gr_stretch.gif" border="0"> and i tried all the different settings 4 cylinder,8,coil per plug....all no go....hmmmm i guess im going to check over everything again....
Old Dec 13, 2001 | 10:27 PM
ExtremeZ28's Avatar
ok its fixed all is well <img src="gr_stretch.gif" border="0"> i gotta get used to that thing flashing in my face hehe first time out testing it...1st gear(rev litmier) 2nd gear(rev limiter) and then missed third DOH hehe ohhwell <img src="gr_stretch.gif" border="0">
Old Dec 14, 2001 | 12:39 AM
bigSS's Avatar
Hmmm, none of that has happened to me. But a few times when I start the car the light comes on and stays on. It doesn't go off unti I turn the car off.
Old Dec 19, 2001 | 10:20 AM
neophytal's Avatar
i need to find mine.. its lost in my house since my z28 got wrecked <img src="gr_sad.gif" border="0">
Old Dec 19, 2001 | 06:22 PM
Importdestroyer's Avatar
Cant wait to get mine, hopefully before Christmas!
HP
98 Vortech TA
Old Dec 20, 2001 | 03:11 PM
y2khawk's Avatar
[quote]Originally posted by Importdestroyer:
<strong>Cant wait to get mine, hopefully before Christmas!
HP
98 Vortech TA</strong><hr></blockquote>
i bet it will be there by then, it shipped on the 18th <img src="gr_grin.gif" border="0">
