6litereater Designs Projects, Suggestions, and Feedback Thread
#341
I'd be in for one of the gauge plates. It wouldn't need the lighter outlet, there is the (semi-useless) spare under the e-brake handle. Or what about a surround/mount for double din head units? Not sure how feasible that would be.
#345
How about a disc to fill over the cup holder in the center consol? (And rears) Would need a emblem in them though.
Or mabey a cover for the !cig lighter mod !!
Dunno, just throwing out a couple of mabeys....
A rear diffuser would look sick!
#346
where it says camaro on the dash above the headunit just a plastic plate i could drill holes into to put switches in, like how the foglight switch is there except i wasn a different looking switch
#348
How about this.....
http://camaroboy9602.50megs.com/cgi-...interior/6.jpg
The gauge cluster to hold Autometer gauges
#349
Well Id only expect the two ***** on the right, and they might be smaller, but I've seen it done and know it would fit. The fan speed is just a simple electrical switch that could be much smaller or a slider type thing.
#350
I am down for a cupholder delete. But what I would really like that nobody has that I can find for a decent price (if I can find at all) are emblems. I do not care if they are plastic, ABS plastic can be sanded, primed and painted for a good effect. Here's a few I'd be interested in and some other motor swap guys may like as well:
6.6L or 6.6 liters (this would be for anyone with a 400-408ish sized motor)
402 cubic inches or 402 C.I.
408 '' ''
370 '' ''
6.0L or liter
402 or 408 stroker
Anything like that. I am not talking about etching, just individually cut letters/numbers. If itd be possible to leave a small thing piece at the bottom connecting them all that'd be ideal, if not, its still all good.
408 '' ''
370 '' ''
6.0L or liter
402 or 408 stroker
#354
i would also LOVE to get a guage cluster like that .get the back out of plastic & Price and then price w/ Guages...freakin sweet!!! then i could run the pod on the drivers side for the guages i WANT..
#355
Mark, this might sound kinda retarded, but i have had the hardest time finding a piece of blank ABS any larger than 12" x 12". if you could sell blank sheets that are 18"x12" or 24"x12" that might be helpful.
when i did my tail lights i ended up using plexi because i got impatient and couldnt find a large enough piece of ABS.
#359
or call me you have my number. and we can make sure this is what you want.
