6litereater Designs Projects, Suggestions, and Feedback Thread
#463
Just had a thought, but maybe it's just me.
Does anyone else hate their suvisors? I'm talking about the ones mounted on the headliner. They're so cheap and mine are always crooked. Anytime I hit the throttle, one of em swings back.
Some ABS ones that had a clip on the inside to steady and align them would be awesome. But then again, maybe I'm the only one with this problem.
#467
I've been watching this from the beginning (Camaro splitter), you have my attention now Especially if you like 96/97 WS6 cars. I think I like the splitter better on the Trans Am's. When you decide to start mocking up the 96/97 T/A splitters, do you think it will be a bolt-on product. I don't really want to drill or cut my nose. Do you supply stainless hardware or just traditional with the splitters ? Keep up the good work.....
#469
taken off frrax posted by z28tt:
alan blaines car:
You can't see in this pic that the undertray makes a 2" radius bend upward just aft of the panhard rod, and the vanes continue forward for a couple inches past the bend. I should drop the whole thing about 3" and trim the vanes.
and from the guy who built it for the black car:
some good links to read through:
http://dsr.racer.net/tech_info/aero/diffuser.htm
http://www.mulsannescorner.com/diffuser.htm
http://www.scienceofspeed.com/produc...body_diffuser/
http://www.eliseparts.com/shop/image...ffuser_LRG.jpg
http://www.eliseparts.com/shop/image...ifuser_LRG.jpg
http://www.hennesseyperformance.com/...hp?Item_ID=176
diffuser off a Ford GT
hate to tell you this Mark, but you have A LOT of hw to do on this one
oh, and ughh, i want one for the SS, i want it to seal up to my CME valance and just leave the opening for CME tips, and attach on the front side of the rear end (completely covering the underbody rear section). i've been thinking of doing this for some time now
Rule of thumb to keep flow attached to a surface, is that the diverging angles need to be 15 degrees or less. You're going from a narrower in between the rear tires to the full width of the car after the tires (about 24" more), so they should get wider to maximize the downforce and minimize drag.
alan blaines car:
i built the diffuser out of aluminium. i basically copied what i had seen on some of my diecast toys of racing vipers, except i didn't extend the diffuser past the rear bumper as the viper engineers had. i also didn't have a complete underbody tray for the car because i ran a flexible front spoiler approx. 1" off the ground that forced a lot of the air around the car instead of under it. i figured the most turbulent air i was trying to control was mostly coming in around from the sides. i don't remember what gauge it was, but i think it was 3/16" thick or so. [fairly rigid] i built the prototype out of cardboard and then had a local fabrication shop build it. my car had a fuel cell hanging back there that was designed to break away in a catastrophic accident, so this diffuser actually attached to the fuel cell "cage" that surrounded it. it was a pretty simple piece with the leading edge approx"2 inches from the rear axle. that leading edge had a 2" lip bent upwards at 45 degrees to keep air from going above the diffuser. each vane started all the way forward on the flat surface. in other words, the vanes were the full length of the pan. the horizontal surface of the pan was basically flush with the fuel cell until the rear edge of the cell, where it started going upwards to meet flush with the rear bumber fascia. the same thing was done on the sides of the cell to meet the side edges of the bumper fascia. the vanes were then shaped so that the bottom edges were all parallel to the ground. the bottom edges were roughly 3.5" above the road surface. the whole thing just attched to the fuel cell cage with four quick release pins because it was necessary to remove it sometimes to service the cooling pumps for the transmission and rear differential which were mounted under chassis above the diffuser. also, it was necessary to remove it to load the car into the trailer on occasion.
#471
Should be interesting but I'd need to see something closer to what it would look like on a T/A. On one hand, it would be good for the guys that have dumped exhaust, but what would you do for those who have it going out the back?
#472
#474
Yea, I was wondering that also LustrousWS6. I would love a rear diffuser for my TA but I have dual tipped exhaust that fills up the back end nicely. Where exactly would the blades go? Will it be a flat piece that goes underneath the bumper like the above pics?
#478
a rear diffuser helps to prevent air from getting trapped in the pocket our gas tanks sit at the rear of the car, that areas a huge parachute just trapping air. it also smooths the air out as it passes under the car making the air that is passed through faster and smoother. helps with rear down force as well
