parts check list
Circle D Torque Convertor
TransGo HD-2 shift kit
TransGo Aluminum Forward Accumulator
TransGo Aluminum 1-2 Accumulator
TransGo Seperater Plate
B&M Trans Cooler
and of course fluid and filter.
Will a 14,000 BTU cooler be enough for a 3000 stall convertor? I might be able to get a new open box one very cheap. Am I missing anything? Thanks
B&M Trans Coller
You should get a front seal.
The HD-2 kit comes with some internal parts that should be installed. Good time for a beast sunshell, better 3-4 clutch set, TransGo pump ring kit ($10), pump bushing, pump o-ring, pump gasket. That o-ring that goes on the input shaft. Pump bolt o-rings.
Thats what I did. EDIT: the kit has you adjust the servo, so new servo cover o-rings, might as well change the servo rings while you're right there. You can get the parts cheap seperate or get a paper and rubber kit for around $40, and it even comes with new sep plate screens.
However if its something you want to do, props to ya man. Good luck!
I kept my 1-2 because it was aluminum, I don't know if you can use a pinless with the transgo stuff on that one.
I got a pinless for the forward accumulator because it was plastic and had a smaller pin.
Those are the only two. EDIT--I forgot about the Fourth gear accumulator. IIRC I used my stock one and it was aluminum. I always plug the feed hole for that one so for me it didn't matter.
The trans is a 2002, I've seen older transmissions that used the same accumulator piston in both FYI.
From my experience when the spring in the 1-2 accumulator breaks it makes it shift harder because it looses it's movement. But like always, failures can have many different symtoms.
Any way so if I just do the 3000-3200 stall convertor and then get it tuned, that should take care of some of the deffiencies of this tranny?
Thanks.
Thanks.
No need for a shift kit but i have read it does shift better. Your trans will be perfectly fine either way. Many people over 100k miles are not running shift kits with 3800-4400 stalls. Dont worry about it, especially if your only going with a 3000-3200 stall. Its mostly in the tune anyway, just make sure you have a good tuner who knows what they are doing.
On another note, did you buy a stall yet?
Now the transgo kit you mention comes with stronger 3-4 release springs, and stronger forward springs.
Now read this
And these are parts you're going to have and not install.
