stalled auto's for the street.
Old Dec 3, 2008 | 07:50 PM
kngkahious's Avatar
Default stalled auto's for the street.
i have a 2000 a4 camaro bone stock. got a little spray on the way and thinking about a stall. i've had a stall before but it was a 5500 in a bigblock drag car. nothing for the street i was curious 1 is the 4l60e as bad about buring up as people say they are. 2 how much will the stall affect mpg in a street car. i was thinking a 3k 3.5k stall in a daily driver . is that to much for a daily driver , will it burn up the tranny ? i've been told the stocker's are junk.
Old Dec 3, 2008 | 07:57 PM
-1SLOWSS's Avatar
https://ls1tech.com/forums/automatic...0e-handle.html
Maybe this will help
I'm running a 3500 stall and it is just fine on the street. Once it locks up on the highway I still get 21mpg with a 3.73 gear in the back. Just make sure you put a cooler on and keep the fluid fresh. Adding a shift kit isn't a bad idea either
Old Dec 3, 2008 | 08:22 PM
chevyz2801's Avatar
i have a pro yank 3400 and like it but i would go a little higher if i got a new one
Old Dec 3, 2008 | 08:37 PM
kngkahious's Avatar
lol your sig is pretty funny! that helped a little . i guess i really just need to know what size stall to put in my car.
Old Dec 3, 2008 | 08:57 PM
Formulals187's Avatar
I have a 3200, I love mine on the streets and the strip, with a 3.73 gear im getting almost 21 down the highway, I put in a trans cooler (smart decision especially for the highway). If i were to do it again i would definitley go with a slightly higher stall
Old Dec 3, 2008 | 09:05 PM
kngkahious's Avatar
so a 3500 is a good one for the street then. on the highway you droped what 4-5 mpg ? what about around town i bet that is a big drop from stock.
Old Dec 3, 2008 | 09:06 PM
kdavis's Avatar
4c(3800-4000) stall and i got about 19. but the engine did have 152000 miles. biggest thing is add another trans cooler.
Old Dec 3, 2008 | 09:08 PM
kngkahious's Avatar
for the most part it will be fine as long as i get a trans cooler .
Old Dec 3, 2008 | 09:23 PM
jsteele90's Avatar
i dd a vig3600 it gets about 14-15 around town and about 28-30 mpg on the highway. mods to tranny are vig3600,summit deep trans pan,24k gvw trans cooler, and a autometer trans temp gauge
Old Dec 3, 2008 | 10:09 PM
SSmoken's Avatar
i have a 4000 with 3.73's. not sure what mpg i get but it didnt fall off a whole bunch campared to stock probably like 5mpg less or so. hwy isnt different since its a lock up. just get a trans cooler and you that should PRESERVE your tannys life a little longer lol.
Old Dec 4, 2008 | 06:05 AM
-1SLOWSS's Avatar
The stall didn't drop my mpg on the highway, my Procharger and 3.73 gear are the culprits there. As for around town, I don't even bother trying to check it!! LOL I like my Yank ST3500 very much on the street, and it even does well raising heck up in the mountains. Nothing like watching the look on the import guys faces when we are sitting at a stop light and I stall it up and get the supercharger whistling.
Old Dec 4, 2008 | 08:12 AM
kngkahious's Avatar
that makes sense . well as far as a brand way does everyone seem to buy a yank for the ls1 there and other good companies i've used before in my race car's b&M ,tci , and so. why the yank?
Old Dec 4, 2008 | 08:15 AM
kngkahious's Avatar
also what gear is most likley in my car? the guy i got it from said a 2.73 i know the m6 is a 3.42 but this is an a4 .
Old Dec 4, 2008 | 08:17 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
We offer a 3600 10" billet lock up for your application that will not hardly effect your fuel mileage.these converters will see .5 to .8 tenths gain on a stock car with no mods.It also loves the jug.The converter has a 3 year warranty with 1 free stall change.
Thanks,
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Dec 4, 2008 | 08:23 AM
Circle-D's Avatar
A stock 4L60E trans should hold a little spray, but you never know. I know stock 6 cylinder cars that have burned up a tranny. I also know heads/cam guys who have over 100K miles on the stock tranny and it still works great. I think every performance auto should have a high stall converter, but I am a little biased. They just work better. Technology has changed a lot, you can get a 9.5" 3500 converter that almost drives like stock. If you want just a little bump in stall, I have a 11" 3200 converter that drives like stock but flashes higher at WOT. Good luck and if you have any more questions let me know.
Chris
Old Dec 4, 2008 | 08:38 AM
Blazingz28's Avatar
So.. I'm the second owner, and my tranny fluid has obviously never been changed.
Anyone think it wuold be best to avoid getting a stall, I know it would be Bad to change my tranny fluid at this point, 125k. I know that doing a stall I'd lose a lot of the old fluid, any advice?
Old Dec 4, 2008 | 09:07 AM
TXZ28LS1's Avatar
with that many miles man, i would just save up to get a built tranny and a stall from one of the sponsors.
Old Dec 4, 2008 | 09:08 AM
TXZ28LS1's Avatar
my 02 Z has a vig 3200 stall and does pretty well for a daily driver. i probably could have gone slightly bigger, but i wanted my car to feel stock as much as possible. so im happy with my 3200 stall.
Old Dec 4, 2008 | 11:16 PM
kngkahious's Avatar
so you make a stall that is like stock under normal driving but under wot they have a higher stall speed. i have never heard of that! all i want is a good stall for the street that drives like stock and i'll get great mpg like now. as this is a dd street car before anything else.but when it's time to do the damn thing i can get it done. tranny's are not my department so i have to ask?'s. i really want to be able to take it to the track and bust off a solid 6.90-7.0 pass on spray 150-175 ( street trim) with sticky tires. is that not reasonable.
Old Dec 4, 2008 | 11:19 PM
kngkahious's Avatar
so what do you guy's have or reccomend for what i am looking for? can you meet my needs or get close .
