4L60E Problem, Need Insight
Old Dec 8, 2008 | 09:29 PM
ponchjoe's Avatar
Default 4L60E Problem, Need Insight
Hi Guys, I'm looking at 94 Formula with the A4. It appears that 1st and 4th gear are not working. Anyone have any ideas? Am I looking at a total rebuild?
thanks,
Joe
Old Dec 8, 2008 | 09:39 PM
performabuilt's Avatar
LS1Tech Sponsor
1st and 4th would point to the 1-2 shift solenoid being bad since its used in both these gears, So may just a simple fix
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 8, 2008 | 09:59 PM
the_merv's Avatar
Could it be in Limp mode?
Old Dec 8, 2008 | 11:45 PM
Elliott's94Z's Avatar
How about the forward spragg? That's the roll mine played out..
Old Dec 9, 2008 | 06:02 PM
ponchjoe's Avatar
It would be great if it were just a solenoid but the fluid is awfully brown. I only drove it around the block so it never got over 30. As far as limp mode, wouldn't the SES light be on?
Old Dec 9, 2008 | 06:04 PM
LS1Tech Sponsor
Should be on in either case, But the only thing that 1st and 4th have in common is the 1-2 solenoid so that is definatley what I would try first
__________________
Call 888-744-6542
Old Dec 9, 2008 | 08:45 PM
ponchjoe's Avatar
Performabuilt,
Thanks for your insight. What years of 4L60E will fit a 94? 93-97?
Joe
Old Dec 9, 2008 | 09:16 PM
LS1Tech Sponsor
Well only a 94 will fit a 94 without some modifications I am afraid
__________________
Call 888-744-6542
