Converter or not?
Old Dec 17, 2008 | 08:40 PM
StreetSilverado's Avatar
Default Converter or not?
Hey guys, I'm in a little situation here. I just traded my truck for a 99's SS. Anyway its got a few bolt-ons and a TSP 231/237 cam...(Can anyone help me with the specs on this cam? I can't find anything on it.) Well it has a stock stall and it really needs a stall, it is drive-able...but when I put it in gear it wants to die and tries to run through the brakes but like I said its tolerable. To get to my point the car runs strong and great but is slugish taking off at WOT, so in that case I have no problems with spinning from a dig . It really pulls hard around 1800+ and the *** end gets a little loose when it goes into 2nd other than that its great. I'm just worried about it not ever going to be able to hook up. Any input on this will be helpful, I'm all ears.
Old Dec 17, 2008 | 08:58 PM
Kingc8r's Avatar
Just run DRs or a regular Nitto 555 or BFG tire in a 275 or wider. I would get a stall that it at least in 3600 stall range. I'm personally going with a 4000-4400 stall.
What are your plans for it? Are you going to spray it? I would talk to Circle D, Yank or Vig... about your goals
Old Dec 17, 2008 | 09:02 PM
CETAWS6's Avatar
If I were you, I would get a stall. I'm assuming you have an a4 seeing that you asking about a stall. If you decide to get a stall, a 3200 stall probably will suit your needs. Some guys here run much bigger stalls but you can't go wrong with at least a 3200. It's all up to you bro. Also, if you wanna hook, get some drag radials like nitto 555r or mickey t's. Mickey T's hook better. I just got some nitto 555r II's in the rear. Haven't really got into them yet.
Old Dec 17, 2008 | 09:03 PM
CETAWS6's Avatar
BTW, nice ride man.
Old Dec 17, 2008 | 09:14 PM
Thanks bro, I didn't do any work to it the guy before me did and he did a great job lol. It already has Nitto 555R's in there rear. I plan on in the future building a 408 stroker for it but I'm sure that will be a while from now. I'm just wanting to get into the low to mid 11's. I'm very impressed with how it runs right now. Too bad most the tracks here are shut down for the year
Old Dec 17, 2008 | 09:16 PM
I'm also aware it will take some money to get that fast...I was planning on going with a 3600, but then got to thinking. I think I'll go ahead and get a 3600 here in the next couple of weeks as the money allows. I'm sure I'm not the only broke MF'er on here
Old Dec 17, 2008 | 09:20 PM
I'm really undecided man about the spray...I'm sure my friend will talk me into a 75-100 shot but nothing major as I'm too much of a pansy to even have it on the car , I've just seen way too many backfires. Right now it has
-LS6 intake
-LS6 heads
-Comp 918's springs
-Pacesetter LT's
-TSP 3" ORY
-MTI clear LID
-TSP 231/237 cam (I don't know the specs)
-3.73's
-TSP Tuned
-Nitto 555R's in there rear
and they are 275/40/17's
Old Dec 17, 2008 | 09:26 PM
Thanks for the input also guys, I know I'm just getting my post count up . I'm pretty excited about getting a stall my friend said it should run a hell of a lot better and should run high 11's. Is that possible with the set-up on it now?
Old Dec 17, 2008 | 09:28 PM
00cls1camaross's Avatar
run a dry shot, no backfire.
get a 4000.
/end thread
Old Dec 17, 2008 | 10:10 PM
crmartin99's Avatar
dry shot's don't backfire anymore? LOL!!!
Old Dec 17, 2008 | 10:14 PM
they dont spray fuel.... just nitrous
Old Dec 18, 2008 | 07:14 AM
wyndzer's Avatar
Dear Clueless in AZ,
Dry shots add fuel after the N2O passes through the MAF. Have a great day.
Old Dec 18, 2008 | 11:56 AM
dear stupid ******* nc resident. Backfires happen from puddling in the intake from wet shots...
Old Dec 18, 2008 | 02:03 PM
SSmoken's Avatar
dear everyone,
n2o + 4000 stall + dr's = OWNING ALL.
Old Dec 18, 2008 | 02:52 PM
crmartin99's Avatar
actually, backfires normally occur when there is not enough fuel to burn all the n2o, causing a massive "leaning" out effect.
Thats the whole POINT of a wet kit on an efi car, puddling is very rare.
stupid ******* arizona resident.
Old Dec 18, 2008 | 03:16 PM
I think I'll go with the 3600 PI, Circle D, etc I've heard nothing but the best about circle D. And hopefully a Lvl 2 tranny as soon as I can scrape up the money
Old Dec 18, 2008 | 05:32 PM
Circle-D's Avatar
I would recommend a Circle D 3C billet street/strip series. It is rated 3500-3700 stall and will really wake the car up. It will address all the weak areas you mentioned, and it will feel like a different car. It has the billet front and piston, so it is very strong. I have a lot of guys running this converter on the street with no problems. You gas milage might drop about 1 MPG, hardly noticeable. Give me a call if you have any questions or shoot me a PM. Free shipping for tech members.
http://www.circledspecialties.com/Co...Pages/LS1.html
713-895-8834
Chris
Old Dec 18, 2008 | 07:31 PM
Sounds like a great deal, hopefully I'll have one ordered here in the next two to three weeks
Old Dec 18, 2008 | 07:41 PM
wyndzer's Avatar
Wrong, and nice womans car LOL
