Manual vs Auto(locked)
Old Dec 24, 2008 | 12:00 AM
w3s1c0a5t's Avatar
Default Manual vs Auto(locked)
Would an auto be more efficient than a manual if the converter is locked?
Old Dec 24, 2008 | 02:10 AM
cals400ex's Avatar
i would think the manual would still have an advantage if any due to the weight.
Old Dec 24, 2008 | 10:23 AM
01ssreda4's Avatar
i say manual too but only bc of weight. i think it would be unnoticeable
Old Dec 24, 2008 | 10:51 AM
Wesmanw02's Avatar
Manual always has the advantage in terms of parasitic loss, regardless if the auto has a lockup converter or not.
A manual trans is nothing more than a couple of parallel shafts with meshed gears between them. So you have to overcome the friction between the gears and the bearings, nothing more.
Automatics have much heavier rotating internals, and they also have pumping losses due to the front hydraulic pump that the torque converter drives.
So basically an auto will always sap more power than a manual trans by design.
Old Dec 27, 2008 | 06:22 PM
w3s1c0a5t's Avatar
Thanks guys. Makes sense. Thats pretty much what the conclusion I had come to but being far from an expert thought id check with you guys
Old Dec 27, 2008 | 06:36 PM
performabuilt's Avatar
LS1Tech Sponsor
Yes but all things equal and the auto with the right converter and regardless of those numbers on the dyno the auto will be at the end of the track first lol
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 28, 2008 | 05:55 AM
the_merv's Avatar
Veteran: Air Force
True. But the T56 has it on maintenance issues, one of the reasons that I swapped over.
Old Dec 28, 2008 | 11:41 AM
LS1Tech Sponsor
I don't know if I would say that either , I spend alotta time on the GTO forum and many of those are t56 and while true the trans holds up ok + - those guys are constantly talking about eating clutches and how expensive that gets and we even get a good number of F Body guys buying autos from us who are switching from the T-56 to the auto for that reason since we have no core requirement.
I think what it comes down to really is everyones looking for that indestructible maintenance free part when there dealing with HIGH PERFORMANCE but the reality is there is no such thing. When you start making 500-600-700 and more RWHP wether its drive line, engine whatever your going to have stuff break. Reminds me when I was 16 and i broke my rear a few times at the time I didn't know how to set one up myself and I was whining to the mechanic because it was costing so much and he looked at me and said "You play you pay if you don't wanna pay the go buy a little compact car and drive like you have some sense" He was right of course I didn't do that and over the years i have broken everything from crankshafts-transmissions- clutches-rear ends and even once ripped the rear loose from the unibody on a mustang I had its just all part of the performance game,
I think it all kinda evens out from my observation on cost and maintenance on the auto or the manual.
__________________
Call 888-744-6542
Old Dec 28, 2008 | 11:54 AM
daniel6718's Avatar
i disagree also...2 years running 9s with a 60 and havent touched it but ti check fluide every once in a while...6 speed guys consistantly break clutches....trannies....rear ends... have to worry about breaking tires loose on gear changes ect...
Old Dec 28, 2008 | 02:30 PM
w3s1c0a5t's Avatar
Im hoping that MVB + stall are going to be a healthy combo on the street especially with the lockup switch for rolls.
Old Dec 28, 2008 | 03:30 PM
LS1Tech Sponsor
If your talking about down shifting while locked at WOT very very bad idea. The impact and stress of upshifts and downshifts with the converter locked will be more than a little extreme you will likely break something for sure
__________________
Call 888-744-6542
Old Dec 28, 2008 | 07:59 PM
w3s1c0a5t's Avatar
If that was at me that wasent what i ment. I ment hitting the lockup after the shift.
Old Dec 28, 2008 | 09:28 PM
LS1Tech Sponsor
ok well that might be ok if your converter is made for WOT lockup But definatly don't let it
be locked during any shift up or down
__________________
Call 888-744-6542
Old Dec 29, 2008 | 01:01 AM
w3s1c0a5t's Avatar
Yes sir.
