Transmission temps
Old Dec 28, 2008 | 09:19 PM
boilertwinkie's Avatar
Default Transmission temps
Running a 160 stat and a 2-3 quart extra pan, will I be able to handle a 3K stall/ what temps will I be running?
Old Dec 28, 2008 | 09:25 PM
performabuilt's Avatar
LS1Tech Sponsor
Well the 2-3 quart pan extra wont really help . I would ad a cooler its cheap and its easy
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 28, 2008 | 10:40 PM
jsteele90's Avatar
i have a 3600vig,bm 24k gvw cooler,summit deep trans pan and mine has never been over 175 degrees
Old Dec 28, 2008 | 11:04 PM
tptransmission's Avatar
Closed ex-Sponsor Account
Deeper pans help from a thermal mass perspective. Obviously the cooler is more benefitial if it get adquate airflow. For vehicles that perform hard launches. drag racing and or road course racing the deep pan will help minimize loss of prime to the pump.
Old Dec 28, 2008 | 11:08 PM
LS1Tech Sponsor
I would agree on the hard lauch part, And while yes it does take longer to heat up a larger volume of fluid it also takes longer to cool it so no gain no loss .
__________________
Call 888-744-6542
Old Dec 28, 2008 | 11:09 PM
FLT's Avatar
FLT
I feel more oil is always a good idea as long as ground clearance is not an issue. In some cases a factory truck pan works just fine and is very affordable. If you want a deeper pan the TCI pans are what I like to use. With a high stall converter a cooler is always a must. The cooler the better. Vince
Old Dec 29, 2008 | 12:09 AM
01ssreda4's Avatar
B+M 24K. get it.
Old Dec 29, 2008 | 12:45 AM
germeezy1's Avatar
It seems like your asking wether you will need a cooler or not. YES YOU NEED A TRANSMISSION COOLER WITH A STALL! Don't skimp either unless you don't like your transmission much.
Old Dec 29, 2008 | 01:21 AM
Camaro396's Avatar
I don't get how a pan wouldn't help? When I put my deep/finned Derale pan on, my trans temps dropped 20 degrees.
Old Dec 30, 2008 | 11:41 AM
I had a derale on my first fbody but didnt have a temp guage. thanks for all the input. I really dont like my trans much anyways. I might just swap it out for a built one when I decide on my TC.
Old Dec 31, 2008 | 10:02 AM
bigboykilroy's Avatar
I have a yank SS4000 and a Trick Flow Deep Pan, and a cooler...driving around town all day long having fun on a hot day hime has never gotten over 180.
We put in coolers on anything over 3000...heat+transmission=poor performance
Old Dec 31, 2008 | 10:24 AM
LS1nut377's Avatar
yes stall+ heat + transmission+ no cooler = death to transmission
Old Jan 1, 2009 | 09:47 AM
FLT's Avatar
FLT
We are located in Wood Dale if you decide to get a unit locally. Feel free to give us a call to discuss your option or stop by to see the shop. Vince
Old Jan 1, 2009 | 08:34 PM
twinturbo496's Avatar
If you install a good gauge in the pan of your transmission I bet you will be amazed at how fast the oil temperature can go up. I had a 700R4 with a 3800 stall behind a 468 bbc, Against the converter it would jump 150 degrees in just a few seconds. The way I see it, if your car isn't moving, all of the energy (maybe 300+ hp) is going into heating up less than 3 gallons of oil, once the oil is hot, it is going to take more than just a big pan to dissipate the heat, you need a good heat exchanger, something much better than the factory installed.
