Converter Install?
Old Jan 2, 2009 | 09:59 AM
95Yardbird's Avatar
Default Converter Install?
What all do I need or replace to install a new torque converter?
Old Jan 2, 2009 | 10:30 AM
01ssreda4's Avatar
i would replace at least the front and rear seal on the trans. and fluid/filter.
Old Jan 2, 2009 | 02:37 PM
95Yardbird's Avatar
It's a new trans. Should I get new bolts for the flywheel and converter? What bolt sizes? Should I get a new flywheel? What brand? Will I need new shims?
Old Jan 3, 2009 | 12:17 PM
01ssreda4's Avatar
my converter came with new bolts. but if it didn't i woulda reused the old ones. most dont need shims.
Old Jan 3, 2009 | 04:35 PM
jetlag's Avatar
You'll have to measure for that when you get the stall in the trans.
Old Jan 4, 2009 | 09:53 AM
Nabdrill's Avatar
Can I get the details on installing the converter, as far as what and where to measure? I've got a Vig 4400. I'll do the install with the motor/trans out of the car.
Old Jan 4, 2009 | 10:55 AM
mike13's Avatar
NAPA BK641-2075 is the part number for the converter bolts, stock size. they're shouldered with loctite already on the threads.
If it's a Yank converter it might use 6 bolts to mount. If it's a TCI they use larger bolts which require you to enlarge the mounting holes with a 7/16 drill.
I would check with the converter manufacturer to see if they use standard LS1 bolts.
Old Jan 4, 2009 | 01:43 PM
cals400ex's Avatar
my yank uses the standard 10mm bolts. they actually send new bolts with the converter. however, the ones they sent are not very long. i went out and purchased bolts that were 16mm long instead of the 12mm ones they sent. if i would of had the bolts before i had the converter i would have checked to see if 20mm bolts fit. i had a feeling they would but it was too hard to check when the tranny and stall was already bolted in the car.
Old Jan 4, 2009 | 01:44 PM
cals400ex's Avatar
check this out:
https://ls1tech.com/forums/automatic...allations.html
Old Jan 4, 2009 | 02:30 PM
the_merv's Avatar
Make sure you line it up or you will **** up the Pump.
Old Jan 4, 2009 | 02:43 PM
Nabdrill's Avatar
Originally Posted by cals400ex
I should've done a search.... but anyways, THANKS ALOT!
Old Jan 4, 2009 | 03:07 PM
RippinZ121's Avatar
MAKE SURE you blow out the old coolant lines!
