4L60E Problem Need help, its my DD!
It just wasnt in gear, but the indicator on the shifter hadnt moved. I manually shifted it to 3rd, and it kicked in, then i slowed at the bottom of an off ramp. I started driving, and 1st/2nd felt ok, then 3rd just wasnt there.. if i played with the shifter manually, i could get it to shift.
Fast forward, to my drive home, and 1st/2nd was fine still, and 3rd was neutral it seemed. i could get it to shift, but not sure how i did it, just moving the shifter from 2nd to 3rd, no real pattern or set way to get it to shift.
Got home, and checked the fluid (All of 5.5miles), it didnt seem burned? What should i look for? Thanks in advance.
https://ls1tech.com/forums/automatic...sion-sale.html
but if it wasn't that time I think it might have been the time where my rubber seal lip tore and folded over in side my input drum, but either way I had to tear apart...
Yes, in drive 1-2 is ok, then it will go neutral when it shifts to third. If i manually shift around, from 2-3 sometimes it will shift into third i think.
The car is cammed with full bolt ons, an Edge 4000 stall with another cooler, and some spray (Currently jetted for a 175 shot, but i havent sprayed the car since ive owned it.)
Just get one from the sponsor they seam to have a good reliable tranny that you don't have to keep messing with.
I have heard nothing but good things about thier trannys.
Im kind of leaning towards Performabuilt's Level 2 or even 3 (I like overkill) but im also considering selling the car.
